MY98 WRX running with no 02sensor
ratherowna31
Postby ratherowna31 » Thu May 10, 2018 3:44 pm
Ive recently purchased a a 98 WRX with a 3' turbo back and loving every minute of it. We noticed that common hesitation issue from 2000-3500 under moderate throttle but fine under WOT. Replaced fuel filter,cleaned iacv etc. I have read hundreds of forum posts and came to the conclusion the 02 can get very lazy and cause this.
I went and got a new 02 sensor but before installing I decided Id unplug the old one ( located directly behind turbo) and see how it reacted. To my surprise it drove fine with no CEL and basically no hesitation. I left it overnight to cool down and try a cold start where the hesitation is more noticeable. The car performed great with no hesitation. Can anyone help me confirm how many 02 sensors this model has and shed some light why this might be occuring? Thanks
Re: MY98 WRX running with no 02sensor
Postby mv75 » Thu May 10, 2018 6:09 pm
Follow the exhaust and you'll see that there should just be one on that model.
It's just operating in open loop now. If you replace the o2 it should be ok if you got a decent one. The only thing is you may notice a bit more fuel being used. Under wot it's operating in open loop anyway and ignoring the o2.
Delivan
Postby Delivan » Thu May 10, 2018 7:32 pm
My 98 has a later model 2.5 liter engine with a divorced twin down pipe system with an O2 sensor screwed in to block the hole but the wire is cut off the sensor as it is not required. It runs with a Uni Chip piggy back ecu. Had it tuned many years ago when I fitted all the goodies to the engine and it hasn't been tunes since and runs perfectly every time I drive it...Our other GC8 (ver 6 sti) does have an O2 sensor as do our bugs but I think pre 99 didn't use them...
ratherowna31
Postby ratherowna31 » Fri May 11, 2018 1:26 am
mv75 wrote:Follow the exhaust and you'll see that there should just be one on that model.
Sounds about right as I cant see a post cat o2. Not sure if its decent but its a fuelmiser universal 3 wire from repco.
