What to do next?
KingKen
What to do next?
Postby KingKen » Mon Apr 10, 2017 2:18 am
Currently own a 04 STI 2.0L and have done some work to it over the last year or so.
Engine:
Process West 72mm in-guard C.A.I
Process West Top mount
Pro speed racing silicone turbo inlet
ID 1000 cc fuel injectors
Walbro 255 fuel pump
GFB BOV
Exhaust: 3" turbo back with Xforce cannon
ECU: Haltech platinum pro plug n play
Been dynoed and tuned with 230kw
What would be the next logical step for more power?
Re: What to do next?
Postby mv75 » Mon Apr 10, 2017 7:53 am
More like the obvious; Bigger turbo and e85, because all of that you have done is just purely prep work for those things.
specr
Postby specr » Mon Apr 10, 2017 7:57 am
As above. How many k's on the motor? e85 will net you a whole lot more power but you will probably blow up the motor.
So:
- e85 or flex fuel
- Bigger turbo
- Built motor
MY13 STI Spec R - BLACK
KingKen
Postby KingKen » Mon Apr 10, 2017 9:45 am
mv75 wrote:More like the obvious; Bigger turbo and e85, because all of that you have done is just purely prep work for those things.
My main concern is that the engine will blow unless i get forged internals?
KingKen
Postby KingKen » Mon Apr 10, 2017 10:01 am
specr wrote:As above. How many k's on the motor? e85 will net you a whole lot more power but you will probably blow up the motor.
So:
- e85 or flex fuel
- Bigger turbo
- Built motor
I could just e85 and tune. Probably save me from getting a bigger turbo and doing a built motor since its safer in terms of detenation. Not sure if im willing to spend that much on it just yet its got 200kkms on it.
specr
Postby specr » Mon Apr 10, 2017 10:11 am
I was going to E85 my old Forester with 190k and a vf34 turbo. Tuner said my motor would blow
Postby stockhorse » Mon Apr 10, 2017 11:59 am
KingKen wrote:My main concern is that the engine will blow unless i get forged internals?
Didn't the 04 STI come with semi closed deck and forged internals?
Postby mv75 » Mon Apr 10, 2017 12:09 pm
Yea, only if you try and get more out of what the crank can do, and you're a long way off that. If the turbo is delivering the power where you want it, then get the e85 / flex done and get a proper tune so it's not detonating all the time. You wanted to know what was the next step, that is the next step.
Postby ryano » Mon Apr 10, 2017 12:10 pm
indubitably
