Help with engine serial number
h-are
Postby h-are » Thu Apr 27, 2017 10:33 am
Hey All,
Just wondering if anyone can assist in ascertaining this engine serial number. The serial number is 422892.
The car it came from is no reference as its an import and I'd say engine was changed when it arrived in Aus. Engine has also been changed again since so this one is sitting on an engine stand but I cant find any info on that particular number.
Any assistance would be appreciated.
Thanks.
surge
Re: Help with engine serial number
Postby surge » Sun May 07, 2017 7:10 pm
That only seems like just the end of an engine number?
h-are
Postby h-are » Mon May 08, 2017 1:58 pm
There is nothing in front of those numbers, so not sure....
higginz92
Postby higginz92 » Tue May 09, 2017 5:28 pm
If its what I think it is, on the block near the starter motor it will have a line of numbers example 422892.
That's the end of your engine number, the beginning of it would be EJ25 or FA20, example
EJ25422892 would be the engine number, if its what your after that should also be the serial number. Just whatever engine model it is goes first then your digits.
Hope it helps
h-are
Postby h-are » Tue May 09, 2017 8:45 pm
Cheers. Yeah I was thinking that would be the case but the issue obviously is thats what I want to know....
Im sure it would be a 2L but 205 or other I may never know.
closed deck
Postby closed deck » Wed May 10, 2017 8:15 am
Your engine number is just the 6 digits. Sometimes a letter before the 6 digits.
Nothing else.
Long Standing Club Supporter.
h-are
Postby h-are » Wed May 10, 2017 8:18 am
closed deck wrote:Your engine number is just the 6 digits. Sometimes a letter before the 6 digits.
Nothing else.
Ok cool.
Do you know where can I find what it is then?
closed deck
Postby closed deck » Wed May 10, 2017 8:24 am
At the front of the motor, behind and slightly to the right of the alternator will be a raised EJ25 or EJ20.
The letters at the front where the cases meet (usually AABA for example) are the piston sizes in the block they are irrelevant to your needs.
h-are
Postby h-are » Wed May 10, 2017 8:44 am
Thanks for the input CD and sorry, I havent been very clear in my comments. The reason I'm looking for info is find if its a 205 or 207.
