Engine coolant wrx 2.5 2006
nathanipp
Postby nathanipp » Mon May 01, 2017 10:44 am
Is it okay to put nulon coolant into my wrx or should I be using a different brand ? Cheers
Re: Engine coolant wrx 2.5 2006
Postby 05-RSX » Mon May 01, 2017 9:53 pm
More important than brand is type.
I believe there are some coolants that aren't great with Alu. blocks
But more importantly there are two types (A vs B kinda thing) and are incompatible with each other. I think they're commonly referred to as 'red' vs 'green', however just to confuse things come green-coloured coolants are 'red' type.
If you're in doubt dump the lot, do a 'flush' (fill, run, dump) with demineralised water, then refill with coolant of your choice.
I believe the OEM stuff is by Castrol.
I have run Nulon in the RS since I redid the headgasket 6yr/80K km ago.
I run Castrol in the WRX, which is 190K old.
Haven't had a problem with either.
nathanipp
Postby nathanipp » Wed May 03, 2017 3:24 pm
05-RSX wrote:More important than brand is type.
Thanks mate
higginz92
Postby higginz92 » Tue May 09, 2017 5:30 pm
Just so you know the engine coolant types are Green and Blue. Vehicles from 2009 onwards used Blue long life coolant required to be replaced every 150,000kms or 6 Years.
If its green, basically any brand should do just make sure the concentration is on point.
