Oil Catch Cans
neptune11
Oil Catch Cans
Postby neptune11 » Fri Jul 07, 2017 6:29 am
:coffee: Now I know this is probably not a new topic, & I've obviously done some searching, but I wish to know what brand catch cans people recommend? This must be able to handle the rigors of track days.
Also, I'm running a Grimspeed Air/Oil separator, so is it possible to ran the can via this? I've seen it done..!
I'm thinking of running the AVO set up.
Anyone credit this? :thumbs:
Re: Oil Catch Cans
Postby mv75 » Fri Jul 07, 2017 7:02 am
Do it right away. Get rid of that water to oil injection system you currently have.
ls0775
Re: Oil Catch Cans
Postby ls0775 » Sat Jul 08, 2017 3:24 pm
I run the dual Mishimoto unit. https://www.mishimoto.com.au/subaru-sti ... 08-14.html
Pros
Well built, work well. Purpose built.
Cons
The cans are small so need checking during a track day and at the end.
cost to other options.
Leon
2008 WRX STI Spec R * 3
Stumpy - 214KW - PI 1:49:8 (R), Sandown 1:26:2 (S), Winton 1:36:7 (R)
Stocky - 165KW - PI 1:53:6 (R), Sandown 1:26:4 (R). Winton 1:38.6 (R)
Scratchy - xxxKW -
neptune11
Re: Oil Catch Cans
Postby neptune11 » Sat Jul 08, 2017 3:34 pm
ls0775 wrote:I run the dual Mishimoto unit. https://www.mishimoto.com.au/subaru-sti ... 08-14.html
Pros
Cons
Yeah, the Mishimoto stuff definitely looks the way to go...!!
I just ordered a litre capacity Moshimoto catch can, which I'm planning to run off my Grimspeed AOS.. :whistle:
Not sure if that's good idea or not?? :drunk:
h-are
Re: Oil Catch Cans
Postby h-are » Sat Jul 08, 2017 7:27 pm
I have a very simple catch can set up, very cheap (unbaffled) cans from autobarn. Plumbed that return to intake and they work perfectly.
I personally think people spend to much money on catch cans.
Edit: I will edit this by saying I run this on a track only car and it is obviously pushed hard.
Re: Oil Catch Cans
Postby mv75 » Sat Jul 08, 2017 8:31 pm
From crank or heads?
h-are
Re: Oil Catch Cans
Postby h-are » Sun Jul 09, 2017 8:33 am
Both.
Heads are tee'd together then into can then intake. The crank & pcv run into the can then back into intake.
Catches heaps of sheet and the car doesnt have any oil residue in the IC even after winton or PI.
Re: Oil Catch Cans
Postby mv75 » Sun Jul 09, 2017 9:37 am
Wow, ok. I would have done 2 cans for all of them. :)
Good to hear the cheapie is good enough, I might have to have a look in there for one. I'd like to do the heads on mine.
ls0775
Re: Oil Catch Cans
Postby ls0775 » Sun Jul 09, 2017 11:19 am
h-are wrote:I have a very simple catch can set up, very cheap (unbaffled) cans from autobarn. Plumbed that return to intake and they work perfectly.
Agree. Even though I have a purpose built unit, you could make one yourself. Here is the plumbing diagram for a WRX and STI to copy. https://cdn.mishimoto.com/media/product ... lGuide.pdf
Leon
Scratchy - xxxKW -
Big_Red
Re: Oil Catch Cans
Postby Big_Red » Sun Jul 09, 2017 1:17 pm
Just keep in mind, some club days will require you to have a catch can of the same capacity of your engine (capped at 3L). I.e. ej20=2L can
h-are
Re: Oil Catch Cans
Postby h-are » Sun Jul 09, 2017 3:11 pm
Not if it returns to intake though. If blocked off this is true.
jonoe
Re: Oil Catch Cans
Postby jonoe » Wed Jul 19, 2017 9:12 pm
I run an AVO catch can, which in black looks like it was there from the factory, it mounts to the lower section of the left strut tower. Being mostly street driven with the occasional track day I was after a stealth look, but did pay a premium for it compared to a generic catch can
Sent from my SM-G950F using Tapatalk
jonoe
Re: Oil Catch Cans
Postby jonoe » Wed Jul 19, 2017 9:17 pm
This is my engine bay with it mounted, excuse the messy job with the hoses, I installed it at the track before scrutineering
neptune11
Re: Oil Catch Cans
Postby neptune11 » Thu Jul 20, 2017 9:14 am
jonoe wrote:I run an AVO catch can, which in black looks like it was there from the factory, it mounts to the lower section of the left strut tower. Being mostly street driven with the occasional track day I was after a stealth look, but did pay a premium for it compared to a generic catch can
Maybe excuse my ignorance..but how do you check the levels & empty the can? Doesn't look easy access??
I went a 1 ltr Moshimoto catch can, & ran it off my existing Grimspeed Air oil separator.. see how we go??
Re: Oil Catch Cans
Postby mv75 » Thu Jul 20, 2017 9:34 am
Just wondering what size I.D. nipple port cans ya'all using? 10mm good enough on a 12.7mm line?
jonoe
Re: Oil Catch Cans
Postby jonoe » Mon Jul 24, 2017 3:25 pm
@neptune11 it is not the easiest to access, I empty it every time I drop the oil (5000kms) and I check it after every second session at the track. There is a drain bolt at the bottom of the can. At the track I take the can out 2 bolts
neptune11
Re: Oil Catch Cans
Postby neptune11 » Tue Jul 25, 2017 6:33 am
https://youtu.be/1oT8C6QkybA
Here's a little clip of my Catch can set up... I plan to put either braided or silicone hoses in.. :thumbs:
