MY06 EJ25: Secondary Air Valve Dimensions
EddyCurr
Postby EddyCurr » Sun Jul 30, 2017 1:10 am
Posting to ask whether someone with left/right secondary air valves in hand (as fitted to '06+ WRX's and my '06 FXT) would be so kind as to post back with dimensions of the hose barb on the inlet side - ie: where the hose from the air pump (mounted beside the left front strut) terminates.
What I am looking for are:
  • an accurate measurement of the inner dia of the hose barb.
  • a rough measurement of the depth of this bore, inward from lip of the barb down to any significant change in ID or the valve, itself.
  • opinions about how cylindrical (round, parallel) and smooth the bore is.
For reference, I believe these parts to be common to '06 WRX's and FXT's:
Subaru Secondary Air Valve
  • 14864AA030 - Right Hand Side (w/ 2 pin connector)
  • 14864AA020 - Left Hand Side (w/ 5-pin connector inc Baro Sensor)
Thank you
EddyCurr
Re: MY06 EJ25: Secondary Air Valve Dimensions
Postby EddyCurr » Tue Aug 01, 2017 3:29 am
Was the secondary air system (pump & valves) fitted to '06+ WRX/FXTs shipped to Aus/NZ ?
