2002 b4 liberty, ej25t engine conversion from 2012 wrx
jake87
Postby jake87 » Thu Sep 28, 2017 10:13 am
Ive just purchased a 2002 b4 liberty twin turbo with a blown engine.
I can also get my hands on a wrecked 2012 wrx with low k's cheap.
Is there anything that will stop me from doing a engine/turbo and running gear conversion to the b4??
Thanks in advance.. [FACE WITH STUCK-OUT TONGUE AND WINKING EYE]
Sent from my SM-G925I using Tapatalk
REVNURAZR
Re: 2002 b4 liberty, ej25t engine conversion from 2012 wrx
Postby REVNURAZR » Sat Sep 30, 2017 5:53 am
Very much so...
The B4 ECU and wiring won't run the GR 2.5L
Running gear the GR gearboxes use ABS sensors for vehicle speed, so you won't have a working speedometer..
Most common thing I have seen people do is go single turbo. This will involve a long block and ECU from a GD WRX (from what I have read, they plug into the B4 harness) or even a halfcut from a JDM B4 and swap it out and retune for single snail and compression ratio.
But 100% a nightmare to try swap the GR gear into the car and get it all working properly
Good luck
