Torque Settings for Front brake caliper 2011 STi
isamson
Postby isamson » Fri Feb 02, 2018 12:40 pm
Hi everyone. Does anyone know the torque settings for the front brake caliper for an 2011 imprezza STI. ? Factory manual says 114.3 ft lb but I've stripped the threads trying to torque this up to this setting.!!
Re: Torque Settings for Front brake caliper 2011 STi
Postby mv75 » Sat Feb 03, 2018 10:02 am
I've also got a factory workshop manual, but for the 2004, it has differences based upon wheel size. It's pretty insane, the 17" is listed as 114.3, but every size below is only 59 ft lb.
neptune11
Postby neptune11 » Sun Feb 04, 2018 5:06 pm
I tried getting my front calipers off my 2011 wrx yesterday... but had no luck..I've got them off previously to change pads, but just no chance this time...sheet!!
MY 11 WRX Hatch
WRC Blue
#Tuned & Serviced by Got it Rex
#Upgraded parts by Tuspeed
#Steering & Suspension by Trutrack
#Engine rebuild by Top Torque
isamson
Postby isamson » Sun Feb 04, 2018 8:21 pm
From the little I've read on the net, the Subaru caliper bolts have been known to seize up due to the heat. Advisable to use anti seize copper grease when you bolt them in. Doesn't really solve your problem of getting the out in the first place. Maybe try soaking them with penetrating oil WD40 etc ?
Note also that you can change the pads without removing the calipers. Just remove the 2 pins that hold the pads to the calipers to slide the pads out.
neptune11
Postby neptune11 » Tue Feb 06, 2018 7:01 am
isamson wrote:From the little I've read on the net, the Subaru caliper bolts have been known to seize up due to the heat. Advisable to use anti seize copper grease when you bolt them in. Doesn't really solve your problem of getting the out in the first place. Maybe try soaking them with penetrating oil WD40 etc ?
Yeah, I'm aware of all that, I also needed to take the rotors off to get machined previously.
This time I need them off for installation of extended wheel studs..
I'll keep trying though.
MY 11 WRX Hatch
WRC Blue
KevO-954
Fireblade/WRX Driver
Postby KevO-954 » Tue Feb 06, 2018 6:49 pm
I haven't looked at the torque settings but I think you may be getting confused with the wheel stud pitch which is 114.3mm for STi's. :?
Postby mv75 » Tue Feb 06, 2018 8:02 pm
You tell me Kev0 :) ; Image
I dunno if it's a typo or not, it's pretty insane.
KevO-954
Postby KevO-954 » Tue Feb 06, 2018 9:20 pm
Found this elsewhere: :roll:
Those of you with STis, DO NOT torque to 114.3!!!!
It was the wrong figure inserted in the translation of the manual, 114.3 is for the rims...
Some people have apparently snapped bolts trying to get to 114
Proper torque is 80 ft/lb. on the caliper bolts.
Postby mv75 » Tue Feb 06, 2018 10:21 pm
Thanks for the clarification there. But even 114 for the wheels! Try and be the person with just the basic car tools trying to remove that.
KevO-954
Postby KevO-954 » Wed Feb 07, 2018 7:43 am
mv75 wrote:Thanks for the clarification there. But even 114 for the wheels! Try and be the person with just the basic car tools trying to remove that.
Yeah I reckon that is incorrect for the wheels and is more about the stud spacing in mm. :wink:
Return to “Wheels, Tyres, Brakes and Suspension”
