P. Mu Club Racer
P. Mu Club Racer
Who has them and how are they on street? I have HC800 now, front pads are almost worn down and heaps left on rear so thinking of throwing in a set of Club Racers.
MY15 BRZ (Clubman Class) PBs: PI-1:49.7 Winton-1:36.1 Sandown- 1:26.0
MY15 BRZ (Street Class)
Re: P. Mu Club Racer
fantastic pad for the money. very capable on the track, and not too bad on the street.
my vote is separate pad for road and track! no compromise!
rsturbo92 wrote:fantastic pad for the money. very capable on the track, and not too bad on the street.
Thanks Tim
Fair enough mate!
Hey Zhi mate,
Give the winmax W5s a go up front...
They were awesome on Saturday, & go ok on street..!!
I have a low km set in my gc8, If you always remember that the brakes won't work effiecently cold you should be ok
But if you one to tho the keys to a mate to pick up another 6pack coz you have had to many yourself , I wouldn't run them
2011 -HH 61.79 Calder 1:09 Winton 1.43 Sandown 1.30 PI 1.58
2012 - Heathcote 13.4 Calder 1.22(wet failure) Sandown 1.25 PI 1.59
2013 - Winton 1.44(7psi) Sandown 1.25 PI1.49 Sandown 1.26
Hey Shane its a real toss up between the Winmax pads and the ClubRacer but being the next step up from the HC800 and only slightly more expensive i am quite keen to try them out
And thanks for the feedback JBonDSS, thats the only worry for me but how long does it take to get them to come in? Are they also very noisy?
Should i run Club racer at the front and leave the HC800 in the rear? i don't know what it would do to my car's balance under braking , and end up wearing out the Club Racer's quicker too .
dbz wrote:Should i run Club racer at the front and leave the HC800 in the rear? i don't know what it would do to my car's balance under braking , and end up wearing out the Club Racer's quicker too .
Yeh, I'm not sure on that one mate
As you're running bigger brakes and rotors than me.
I've got the W5s up front and W3s on rear!
- Chocolate Wheels Driver
Hey Zhi, I'm pretty sure Scott (Alpha Dog) is running the Club Racers up front & HC800's at the rear on his 06 STi, he might be able to chime in with this experience/thoughts
Also, how did your new Recaro race seat go at Sandown on the weekend? Are you happy with it?
Snowy wrote:Hey Zhi, I'm pretty sure Scott (Alpha Dog) is running the Club Racers up front & HC800's at the rear on his 06 STi, he might be able to chime in with this experience/thoughts![]()
Hey Snowy thanks for that! Scott where are you!!??
My Recaros felt great
I'm here. The balance with the HC800 rear + Club Racer front on the track and with R-specs is good. The fronts have more bite but the point of lockup/ABS seems balanced across all 4. I don't run the Club Racers on the road except for bedding in... and doing that on sticky road tyres the fronts are locking before the back (which is stable). I agree with the comments above re running them on the road... not as bad as I expected. I have no evidence that the CR's will wear the rotors faster, but others have said they will... and maybe on the road when cold and operating in friction rather than hot material transfer they will. (If you don't understand that last bit ... read more). They don't squeal as much as the HC800's but shims cure that for them both.
I plan to run the Club Racers across all 4 (track only) when the HC800's are done.
Alpha Dog wrote:I'm here. The balance with the HC800 rear + Club Racer front on the track and with R-specs is good. The fronts have more bite but the point of lockup/ABS seems balanced across all 4. I don't run the Club Racers on the road except for bedding in... and doing that on sticky road tyres the fronts are locking before the back (which is stable). I agree with the comments above re running them on the road... not as bad as I expected. I have no evidence that the CR's will wear the rotors faster, but others have said they will... and maybe on the road when cold and operating in friction rather than hot material transfer they will. (If you don't understand that last bit ... read more). They don't squeal as much as the HC800's but shims cure that for them both.
hey mate thats awesome feedback much appreciated
Hi dbz, I was in the Silver 15 STI running with you at Sandown (i think) on the 30th, I was running RC09's up front with PMU 2 piece rotors and HC800's in the rear, the stopping power is awesome and felt well balanced with no fade noticed in any of the sessions running Yoko Ad08R's. However, I have used over 70% of the front pads up already after just one and a half tracks days and about 500kms road driving. Have now got a set of PMU H12's on order, will see how they go. As for street Driving on RC09's they felt fine with not too much squeal, the HC800s in the rear are really noisy though.
Dozza12 wrote:Hi dbz, I was in the Silver 15 STI running with you at Sandown (i think) on the 30th, I was running RC09's up front with PMU 2 piece rotors and HC800's in the rear, the stopping power is awesome and felt well balanced with no fade noticed in any of the sessions running Yoko Ad08R's. However, I have used over 70% of the front pads up already after just one and a half tracks days and about 500kms road driving. Have now got a set of PMU H12's on order, will see how they go. As for street Driving on RC09's they felt fine with not too much squeal, the HC800s in the rear are really noisy though.
Hey mate thanks for the feedback! Really appreciate it!
I ran the HC800 up front with standard rotors earlier this year and after 3 track days at Sandown the outer right pad failed and disintegrated braking into turn 6 (not fun), after that we pulled the HC800s out and found that with the other 3 pads the compound had become completely separated from the backing plates!. The RC09 gives you a lot more confidence especially with a bit of heat, I will have no chance of even keeping close to you now lol.
Dozza12 wrote:I ran the HC800 up front with standard rotors earlier this year and after 3 track days at Sandown the outer right pad failed and disintegrated braking into turn 6 (not fun), after that we pulled the HC800s out and found that with the other 3 pads the compound had become completely separated from the backing plates!. The RC09 gives you a lot more confidence especially with a bit of heat, I will have no chance of even keeping close to you now lol.
Damn that's scary!
Project Mu Club Racers +1
I use them on th street with no issues. They squeal when cold but performance is right there and are fantastic when warm and fantastic on the track. Seem to last a lot longer than a cheaper pad too.
Good choice
Good choice
www.nuvismedia.com.au
Nick
MY99 V5 STI Type R Coupe
Nürburgring - 9:49.9 BTG
Sandown - 1:25.17
Winton - 1:40.0002
HH - CW 59.66, CW8 65.02, CST 39.59
Phillip Island - 1:59.01
Calder - 1:05.85
Nick
Sandown - 1:25.17
Winton - 1:40.0002
Calder - 1:05.85
funwin wrote:Project Mu Club Racers +1
Good choice
Thanks mate
What about Winmax pads? Has anyone tried them compared to the PMU Club Racers? Which Winmax is equivalent?
Photo credit: Joel Strickland Photographics - thanks Joel!
