03 STI - HALTECH Pro Platinum ECU - 24psi only 247kw atw
MrSuey
Postby MrSuey » Wed Apr 15, 2015 11:02 am
Hi guys,
Just got my car back from Powertune at Wetherill Park for my 03 STI
Here is a rough list of the set up:
GT35R or GT30R bolt on turbo (have to confirm, the code on the plate can not be found on google)
ARP head studs
Cosworth head gaskets
CP forged pistons
1000 injectors
Internal wastegate
Stock cams
ACL race bearing kit
On standard ECU 16psi makes 205atwkw 600nm torq
On Haltech new ECU with Windband controller 24psi only made 247atwkw and only 425nm torq
Question is, regardless of the turbo: has this been tuned right? has it been done by an amateur?
Or does the set up only make that much power with stock cams etc?
I am a bit concerned about the increase of only 40kw with a new $2k ECU.
Any opinions on this?
Re: 03 STI - HALTECH Pro Platinum ECU - 24psi only 247kw atw
Postby ryano » Wed Apr 15, 2015 1:17 pm
you won't make anymore power with a $2k ecu
MrSuey
Postby MrSuey » Wed Apr 15, 2015 1:21 pm
And I thought that was the latest version and could make big power. Are you speaking of 4k+?
MrSuey
Postby MrSuey » Wed Apr 15, 2015 1:22 pm
I would assume they tuned it to be on the safe side. They said if it was pushed for more power it will start to cause problems.
Postby blackrex » Wed Apr 15, 2015 1:34 pm
Where those values gained from the same dyno? the standard torque value is higher than standard, and looks more like a tractive effort value (N not N.m) than a torque value.
MrSuey
Postby MrSuey » Wed Apr 15, 2015 1:38 pm
no, they were at 2 different shops.
KuRT12
Postby KuRT12 » Wed Apr 15, 2015 1:43 pm
What intercooler are you running? top mount or front mount?
Top mount is going to be fairly restrictive of power on 98
MrSuey
Postby MrSuey » Wed Apr 15, 2015 1:58 pm
Plazmaman front mount kit
bazzasti
Postby bazzasti » Thu Apr 16, 2015 10:31 am
MrSuey wrote:And I thought that was the latest version and could make big power. Are you speaking of 4k+?
Stock Ecu will make 300 kW, waste of coin upgrading.
KuRT12
Postby KuRT12 » Thu Apr 16, 2015 10:42 am
Power does seem low for that Boost and Turbo.. but the difference in the dynos could make the gap seem a lot worse.
Stock heads will be restrictive, but i doubt that restrictive?
MrSuey
Postby MrSuey » Thu Apr 16, 2015 11:41 am
Its too late now i cant give it back. It does respond better now, I can definately feel a big difference. But I mean in the long run if I need to add anymore aftermarket mods the new ecu will help wouldnt it
MrSuey
Postby MrSuey » Thu Apr 16, 2015 11:46 am
KuRT12 wrote:Power does seem low for that Boost and Turbo.. but the difference in the dynos could make the gap seem a lot worse.
Im starting to think those guys didnt tune it properly. timing was off etc.
MrSuey
Postby MrSuey » Thu Apr 16, 2015 12:20 pm
am i able to return their ecu and put my standard one back on with the stock tune if im not happy with it?
Postby blackrex » Thu Apr 16, 2015 12:32 pm
Post up the map file if you like.
You cant compare the results from two different dynos in two different shops on different days, there are just to many variables involved, even the amount of tension in the tie-downs used, the tyre pressures and wheel alignment will all have an effect on the final result.
MrSuey
Postby MrSuey » Thu Apr 16, 2015 1:28 pm
blackrex wrote:Post up the map file if you like.
My wheel alignment is a little off just havent got time.
Bottom line is, is the new ecu really worth it in the long run?
Postby blackrex » Thu Apr 16, 2015 4:03 pm
Yes.
MrSuey
Postby MrSuey » Thu Apr 16, 2015 4:12 pm
Thank you all so much for your advice.
MrSuey
Postby MrSuey » Mon Apr 20, 2015 10:03 am
By the way guys, i can feel the heat more now that its on higher boost. is that normal? the gauge is not moving up on the dash tho its just a heat wave through my window.
