re-coding body module after cluster swap
FOZXTC
Postby FOZXTC » Thu Apr 30, 2015 12:00 pm
I have a 2010 WRX cluster to swap into my 2010 forester. I was told i need to get the body module re-coded to match the cluster and transponders. Does anyone know of a melbourne workshop that can do this? They need a Subaru Select Monitor unit AFAIK. I spoke to Subaru docklands and they were clueless.
SUBITECK
Re: re-coding body module after cluster swap
Postby SUBITECK » Sat May 09, 2015 6:07 am
Find a workshop that has a G Scan .It should link it for you .I have done forester to forester 2010 and it worked fine impreza should be the same cheers ...
Return to “ECU's and Tuning”
