Adam's 06 STi (ABSTI)
ABSTI
Postby ABSTI » Sun Apr 19, 2015 12:56 pm
Probably about time I posted up some pictures, I haven't managed to get any worthy of posting.
I've had my 2006 STi for just under a year now, moving up from a MY98 Club Spec Evo II - some things I love & some things I hate compared to the classics, probably shouldn't have gone with black though! hmmm
Most of the mods were on the car when I bought it. I'll probably be leaving it as is, however wouldn't mind looking at the intake side of things.
- Set of forged pistons
- AVO450
- Turbo XS TMIC
- APS BOV
- MRT Turbo Back Exhaust
- Upgraded fuel pump
- Front and rear Whiteline swaybars & kit
- Pink springs
- Front lip
- Pioneer DVD player/DAB head unit & front speakers
Currently running approx 220kw at wheels (although may have had any issue with leaking Y pipe :chair: )
Re: My 2006 STi (ABSTi)
Postby Delivan » Sun Apr 19, 2015 3:35 pm
What workshop is that ???
Postby Lupin » Sun Apr 19, 2015 4:45 pm
Yep car should have been white :P
Looks like Sti docklands to me.
ABSTI
Postby ABSTI » Mon Apr 20, 2015 11:43 am
Lupin wrote:Yep car should have been white :P
Yep, the last dyno day at STi Docklands.
ABSTI
Postby ABSTI » Sat Sep 12, 2015 3:59 pm
Well, probably a good time for an update. About a month ago my car overheated and ended up needing to be towed to Aleck at Got It Rex. We initially suspected that it was an all too common head gasket, also keep in mind that we previously suspected the head gasket was on the way. Engine came out and to our dismay we found a crack in the cylinder/block. To make matters worse, the AVO450S fitted up had crack in the rear housing.
To put all this in context, the car had done 130k and was rebuilt with a set of forged pistons at 30k - we also found that the original head studs were reused when rebuilt with 'Aries' pistons!
It just goes to show, you never know when you're buying a car! Big thanks to Aleck At Got It Rex.
Re: Adam's 06 STi (ABSTI)
Postby Delivan » Sat Sep 12, 2015 5:20 pm
Isn't it frustrating when people try to scrimp and save a few bucks on things like head studs ? And you can never tell if it was the workshop or the guy who owned it who couldn't afford to do it properly... Our sti had been 1/2 done like that..1/2 the previous owners fault, used old head studs but also the builders had put the timing belt tensioners on the wrong way..Cost big $$$ to do it all again properly because of the damage the studs had allowed. Hopefully you will get out of it without too much pain..
ABSTI
Postby ABSTI » Sat Sep 12, 2015 6:18 pm
It has played on my mind as to whether it was the previous owner or builder, probably a combination of both. At least now I know it's going to be done right, chucking a couple of goodies on in the process - it's certainly an expensive exercise.
rsturbo92
Postby rsturbo92 » Sun Sep 13, 2015 9:13 am
R u putting a stock block back in or closed deck to stop the bore splitting?
Sweet car by the way!!
ABSTI
Postby ABSTI » Mon Sep 14, 2015 8:59 am
I decided to get a whole new block and drop in a set of forged pistons in, I had some big doubts in my mind about using anything from the old engine - it also saves us having to crack it open. The car's a daily and absolute max I'd want to push would be <250kw. I'm really unsure as to how the damage even occurred given it was only pushing about 220kw hmmm.
rsturbo92
Postby rsturbo92 » Mon Sep 14, 2015 11:16 am
Fair enough
What pistons are you going to use?
ABSTI
Postby ABSTI » Mon Sep 14, 2015 6:32 pm
Manley turbo tuff, standard size.
R1Titan
Postby R1Titan » Mon Oct 19, 2015 5:59 pm
Lovely sleeper!!
06STi
ABSTI
Postby ABSTI » Mon Nov 23, 2015 6:07 pm
To provide a bit of an update on my build journal;
New engine now run in sporting the ATP STi Silver with a few other tasty mods, huge improvement with the STi Silver over the AVO450S I was running. The car comes on full boost 1k+ earlier and makes more power with less boost!
I also fitted up a new set of wheels in satin black with RE003's punk
BIG Thanks to Aleck, Vin & Ray from Got It Rex, Kyp from ATP & Adam from Tuspeed!
Mod list to date
Manley turbo tuff pistons
ARP2000 headstuds
Killer B oil pick up
ATP STi silver turbo
Turbo XS TMIC
APS BOV
MRT XB turbo back exhaust
AVO 2.4" turbo inlet
Process West cold air intake
ID1000's injectors
MRT XB 3.5lpm 500HP fuel pump
Tuspeed Air pump delete
Tuspeed 3 port boost solinoid
Whiteline front & rear swaybars
Ultrex front strut brace
STI pink springs
DBA T3 4000 front rotors
Pioneer AVH3600DAB
Jaycar Kevlar front speakers
DEFI Racer 52mm gauges – Boost &Oil Pressure
Innovative Motorsport 52mm gauge – Air fuel ratio
S204 style front lip
Standard Enkei wheels powder coated black
Black Tuner wheel nuts
jonoe
Postby jonoe » Mon Nov 23, 2015 7:22 pm
Looks immaculate! Not normally a fan of painting the wheels black, but they suit the car really well. How do you find the 003's? Any idea how much power you are making now?
ABSTI
Postby ABSTI » Mon Nov 23, 2015 7:35 pm
jonoe wrote:Looks immaculate! Not normally a fan of painting the wheels black, but they suit the car really well. How do you find the 003's? Any idea how much power you are making now?
Thanks Jonoe, haven't had the RE003's long enough but have been hearing a lot of great things about them! The car is making roughly 225kw's on 20PSI, it's making full boost by 3500RPM which keeps it punchy .
The car can probably make a lot more, my main goal was to replace the AVO450S with something that spools quick but not necessarily make huge power (the car is daily) - Most importantly SAFE!
ABSTI
Postby ABSTI » Tue Dec 01, 2015 6:29 am
Nothing special, just a pic of the engine bay at the moment.
KuRT12
Postby KuRT12 » Wed Dec 02, 2015 3:17 pm
Damn, those tyres look grippy as!
Good work on being back on the road! love it looks good.
ABSTI
Postby ABSTI » Thu Dec 03, 2015 10:50 am
Thanks Kurt, the tyres are awesome! The car is finally at a point where I'm happy :)
scorcher85
Postby scorcher85 » Thu Dec 03, 2015 10:56 am
Car is awesome mate! Would love to own something as good as that one day in the future. But I bought the same tires yesterday! :thumbs: such a good price too with the buy 4 get one free deal.
ABSTI
Postby ABSTI » Mon Mar 28, 2016 9:02 am
Just an update on mine with a couple of extra goodies, front brace and catch can
