GC8 Wide body lightweight race car
Kevin.Averill
Re: GC8 Wide body lightweight race car
Postby Kevin.Averill » Sun Apr 17, 2016 4:58 pm
So I made some more progress with the car this weekend. Hopefully i can find some more spare time to get the car ready for the 30th.
I am also looking at getting some cooling/induction air out from under the bonnet. Does anyone know anywhere in Melbourne that i can get some louvers ?
I was going to try and cut/plastic weld the NACA ducts to create louvers, But i think that is going to be more work than it is worth.
Kevin
Kristian
Social Committee Kristian
Postby Kristian » Tue Apr 19, 2016 11:50 am
Car is looking great. Ill have to come say hi and have a closer look at sandown :)
------------------ GOT IT REX TUNED 2011 STI SEDAN ------------------
bazzasti
Postby bazzasti » Tue Apr 19, 2016 2:29 pm
Nice one Kev, coming along nicely. A word of advice with the flat floor, you want at least a aluminium RHS every 30-40 mm laterally and you want a rivett every 50-100 mm and you want it supported by the car in at least 8 places. I'm up to version 4 of the flat floor (250 kph at PI and Calder stress it pretty hard) ... it's a very hard thing to get enough strength in there without getting too heavy. You need to be able to stand on any point and not have it flex or it will struggle.
Kevin.Averill
Postby Kevin.Averill » Tue Apr 19, 2016 6:03 pm
bazzasti wrote:Nice one Kev, coming along nicely. A word of advice with the flat floor, you want at least a aluminium RHS every 30-40 mm laterally and you want a rivett every 50-100 mm and you want it supported by the car in at least 8 places. I'm up to version 4 of the flat floor (250 kph at PI and Calder stress it pretty hard) ... it's a very hard thing to get enough strength in there without getting too heavy. You need to be able to stand on any point and not have it flex or it will struggle.
Thanks for the advise mate, The section shown is not fixed off yet. I have 20x20 and 25x25 sections spanning from skirt to skirt and bolted to the pan every 600mm. In regards to the weight i am a little disappointed with how much reinforcement i have put in, I just hope the gains are worth it.
I am considering testing and fine tuning it, then using it as a mould for fibreglass.
Do you have any veins in yours ? do you have any pictures or data ?
Kind regards,
Kevin Averill
bazzasti
Postby bazzasti » Thu Apr 21, 2016 10:38 am
Kevin.Averill wrote:Thanks for the advise mate, The section shown is not fixed off yet. I have 20x20 and 25x25 sections spanning from skirt to skirt and bolted to the pan every 600mm. In regards to the weight i am a little disappointed with how much reinforcement i have put in, I just hope the gains are worth it.
Kind regards,
Kevin Averill
The amount of weight does creep up when you need strength - I've considering using steel supports as ally just gets too much and too heavy. Don't have any pics handy sorry.
Kevin.Averill
Postby Kevin.Averill » Sun Apr 24, 2016 3:51 pm
bigBADbenny
Postby bigBADbenny » Sun Apr 24, 2016 4:37 pm
Love it :)
Kevin.Averill
Postby Kevin.Averill » Mon Apr 25, 2016 4:02 pm
I won't make it to Sandown next weekend but i have booked in for round 4 to keep me motivated.
With the under tray 90% sealed i spent the day working on louvers to getting some air out from between the car and the pan.
Does anyone have any opinions on the best way of extracting cooling and induction air from under the hood ? I was thinking about putting louvers about 200mm back from the front edge of the hood, However this would mean some of that warmer air would make its way into the intercooler. I don't imagine it would make much difference, but I'm open to some advice on this.
Kevin
Last edited by Kevin.Averill on Mon Apr 25, 2016 5:53 pm, edited 3 times in total.
Kevin.Averill
Postby Kevin.Averill » Mon Apr 25, 2016 4:32 pm
This is what I'm considering for the extraction.
Kevin
Kevin.Averill
Postby Kevin.Averill » Tue May 03, 2016 7:16 pm
bigBADbenny
Postby bigBADbenny » Tue May 03, 2016 11:26 pm
This chap went for OS bonnet vents bc tmic...
http://forums.nasioc.com/forums/showthr ... 627&page=9
Kevin.Averill
Postby Kevin.Averill » Sat May 21, 2016 7:14 pm
Some more progress, Hopefully this should hold up at Phillip island.
Kevin.Averill
Postby Kevin.Averill » Thu Jun 02, 2016 8:18 pm
The new rotors and calliper rebuild kit have arrived along with some knock back springs for the brake pistons . The rotors are really impressive, and really light.
hopeful the rotors will help to keep some heat out of the hubs and the knock back springs should help with some of the brake knock off at Sandown.
Kevin.Averill
Postby Kevin.Averill » Sat Jun 25, 2016 6:37 pm
Almost ready for Phillip Island!
We had a bit of a panic when we couldn't select any gears when the car was running, It turned out the clutch was stuck. We had to bump the car then let it stall which seemed to disengage the plates.
bazzasti
Postby bazzasti » Wed Jun 29, 2016 9:22 pm
Nice work Kev - looking forward to seeing it in action.
lightyear
Postby lightyear » Thu Jun 30, 2016 4:34 am
The flat floor looks good. You should talk to me about aero. I have just made my sheet road car the fastest MX5 to ever lap Phillip island. I bet it is quicker than most of the WRX club, and it's on its original 212,000 km motor. Oem Mazda turbo, manifold, down pipe and 2.25" exhaust.
MX5 times- Phillip island 1:43.8 Winton 1:32 Sndwn 1:22.0 Brdfrd 1:06 Wakefield 1:10 Calder 1:07
WRX times- Phillip Island 1:48.4 Winton 1:37 Sandown 1:24
lightyear
i don't have a flat floor, would be nice. Just a splitter/under tray up to the front axle. A rear wing and camm tail on the boot, some side skirts, vented bonnet and the fastback.
Kevin.Averill
Postby Kevin.Averill » Thu Jun 30, 2016 11:53 am
lightyear wrote:i don't have a flat floor, would be nice. Just a splitter/under tray up to the front axle. A rear wing and camm tail on the boot, some side skirts, vented bonnet and the fastback.
Good work with the mx5 mate. Are you going to Phillip island this weekend? Ill be looking at a wing for mine soon, Im thinking about going with a swan neck mount. Have you got any advice ? or suppliers ?
This is a crude drawing of the current aero set up (side view)
Kevin
lightyear
Postby lightyear » Fri Jul 01, 2016 9:24 am
I think your rear diffuser should be curved at the floor pan join. How can air stay attached?
lightyear
Postby lightyear » Fri Jul 01, 2016 9:25 am
I will be at p.i on Saturday. Tomorrow..
Swan neck is good. But can be harder to fabricate.
