Leon's MY08 STI Hatch Build [aka Stocky]
ls0775
Postby ls0775 » Sun Dec 18, 2016 6:19 pm
MY08 STI Spec R Hatch
Everything is stock if not listed. [b]
[b]Engine
  1. XForce catback exhaust. Not really a performance mode, I just wanted to hear it.
  2. Whilst it has not been on a dyno, most stock set ups make around 165KW atw.
Suspension and Tyres
  1. MCA XR Series coils 10.7F,12R with -3.3 camber on front, 1mm toe out front, 1.5mm toe in back, 6.5 caster
  2. Hankook z222 (RS-3) or Hankook z221 (TD) 245/40/18 tyres on STI BBS wheels
Brakes
  1. DBA 4000 rotors
  2. Project Mu HC800 pads
  3. Endless RF-650 brake fluid
Engine Safety
  1. 15w40 Diesel mineral engine oil :-)
  2. Koyorad radiator
  3. Mishimoto dual catch can
Electronics
  1. Stock tune
  2. Harry's for data logging
  3. Vbox sport
To Do List
  1. Increase Caster and Camber
  2. Hardrace bushing
Results
See my signature. This setup is 290 points (Clubman) with TD.
Leon
2008 WRX STI Spec R * 3
Stumpy - 214KW - PI 1:49:8 (R), Sandown 1:26:2 (S), Winton 1:36:7 (R)
Stocky - 165KW - PI 1:53:6 (R), Sandown 1:26:4 (R). Winton 1:38.6 (R)
Scratchy - xxxKW -
SJTriggs
Re: Leon's MY08 STi Hatch Build [aka Stocky]
Postby SJTriggs » Wed Dec 28, 2016 5:35 pm
What exactly do you mean by shortened?
Black MY11 WRX Hatch
Tuned with UniChip Q+
stockhorse
Postby stockhorse » Wed Dec 28, 2016 7:56 pm
" 15w40 Diesel mineral engine oil " just for track days?
ls0775
Re: RE: Re: Leon's MY08 STi Hatch Build [aka Stocky]
Postby ls0775 » Wed Dec 28, 2016 8:07 pm
stockhorse wrote:" 15w40 Diesel mineral engine oil " just for track days?
I always run it. Was recommended by my tuner.
Sent from my Nexus 5X using Tapatalk
Leon
Scratchy - xxxKW -
ls0775
Postby ls0775 » Wed Dec 28, 2016 8:08 pm
SJTriggs wrote:What exactly do you mean by shortened?
I came off and hit the wall so it has been 'shortened'
Leon
Scratchy - xxxKW -
SJTriggs
Postby SJTriggs » Wed Dec 28, 2016 8:13 pm
Cool, thats what i assumed... pretty cool. How does it change the handeling? I assume it reduced the weight substantially.
ls0775
Re: RE: Re: RE: Re: Leon's MY08 STi Hatch Build [aka Stocky]
Postby ls0775 » Thu Dec 29, 2016 11:33 am
ls0775 wrote:came off and hit the wall so it has been 'shortened'
SJTriggs wrote:Cool, thats what i assumed... pretty cool. How does it change the handeling? I assume it reduced the weight substantially.
Haha. Whilst the weight reduction was good, the lack of power from removing the drivetrain means it is a Fred Flintstone powered only model at the moment.
Leon
Scratchy - xxxKW -
ratty05
Postby ratty05 » Tue Jan 17, 2017 4:02 pm
Would you be interested in a 6pt bolt in cage for stocky, or stumpy once it's repaired?
ls0775
Postby ls0775 » Tue Jan 17, 2017 8:06 pm
ratty05 wrote:Would you be interested in a 6pt bolt in cage for stocky, or stumpy once it's repaired?
I was considering 4 point as both are road registered.
I was considering a 4 point as both are road registered. Can you tell me a bit more. Make/Model. Compliance/certification level etc.
Leon
Scratchy - xxxKW -
ratty05
Postby ratty05 » Wed Jan 18, 2017 8:58 am
It's a 6pt bolt in made by AGI precision in Sydney. CAMS approved up to state level racing. Will fit a hatch without sunroof (which I should have checked first! That's the reason for selling). I'll double check the details with AGI and can send you through some pics if you like. Never been installed.
Checked details, serial number with AGI is AGI ROPS 738. 6pt cage to suit 5 door hatch no sunroof.
Return to “Photo Gallery and Build Threads”
