resonatorectomy how-to
cpitts
White Liberty SpecB Driver
Postby cpitts » Wed Apr 27, 2005 12:59 pm
Kaaaaay, maybe I should clarify, it's not a huge sound, so wind your window down, turn off your stereo and then drive the car hard with revs over 5500rpm and you'll hear it.
Don't expect the sound of a HKS SS BOV, it'll never be that. It's a very quiet BOV (KSHHH) sound.
wt9bind
Postby wt9bind » Wed Apr 27, 2005 4:14 pm
cpitts wrote:Kaaaaay, maybe I should clarify, it's not a huge sound, so wind your window down, turn off your stereo and then drive the car hard with revs over 5500rpm and you'll hear it.
Ok Fair enough, I get a loud enough whistle through my dump pipe as it is, once I get some more fuel I will hammer it, I only have a quarter of a tank left and have to drive 100km south :?
If anyone sees an 01 Hatch broken down on the Kwinana its me :?
pyro
Postby pyro » Tue May 24, 2005 7:31 pm
Do you have the images for the PVC pipe? You mentioned you were going to do them and does anyone know where we can get the GP moto Elbow joint in australia if the PVC pipe DIY isnt posted.
Let me know guys :D
Grant
plasticboy
Postby plasticboy » Tue May 24, 2005 10:20 pm
I made this for my GC8 Sedan MY00, when i put it in it felt as if it hurt performance rather than gained. I couldn't get it to face straight down, more of an angle so i think that's why.
Flared the pipe with a heatgun and a funnel, fairly easy actually. Bought all the sheet from bunnings
wt9bind
Postby wt9bind » Tue May 24, 2005 10:44 pm
Ok, I have noticed a difference!!!
Not in the noise, but yes throttle is more responsive but.........
drum roll..............
FUEL ECONOMY IS AWESOME!!!!!!!!! I did no other mod, it can only be this what did it. My fuel went from 360km city driving and 440km highway
to 440km city and 505km highway with 10L left!!!!!!!!!!!!!
I am AMAZED!! and yes I drove it hard! none of this no boost crap, Highly recommended along with the upper engine cleaner to anyone!
deafwish
Silver MY06 STi Driver
Postby deafwish » Tue May 24, 2005 10:47 pm
It hurt on the performance because that bend is not a mandrel bend.
Internally, it's smooth on the outside, but the inside has a nasty sharp bend. Tyr get an exhaust shop to replicate the bend with a cheap mild steel mandrel bend.
cpitts
Postby cpitts » Wed May 25, 2005 10:37 am
deafwish wrote:It hurt on the performance because that bend is not a mandrel bend.
deafwish, not sure what your talking about here, u mean the PVC CAI above??? Or something different?
deafwish
Postby deafwish » Wed May 25, 2005 10:45 am
:oops:
Sorry..... :roll:
Yes, the PVC 90 degree bend.
cpitts
Postby cpitts » Wed May 25, 2005 10:50 am
Wouldn't it be better from an efficiency perspective to simply have a straight pipe from the inside of the air box straight out into the guard? Thus there's no bends at all!??
Drew
Liberty Driver
Postby Drew » Wed May 25, 2005 12:11 pm
Try also using 2x 45 degree angles, to make the right angle... makes it a bit smoother....
deafwish
Postby deafwish » Wed May 25, 2005 2:19 pm
cpitts wrote:Wouldn't it be better from an efficiency perspective to simply have a straight pipe from the inside of the air box straight out into the guard? Thus there's no bends at all!??
Yes, yes and yes!
Get the end of it flared slightly though. :wink:
plasticboy
Postby plasticboy » Wed May 25, 2005 8:15 pm
I see.. but would sitting it on an angle like i did hurt performance as well? I couldn't get it to sit straight down unless i made a shorter one.
deafwish
Postby deafwish » Thu May 26, 2005 9:35 am
Just use a short, straight pipe with the end flaired.......... :wink:
pyro
Postby pyro » Thu May 26, 2005 2:11 pm
bah, too much work, is there just something we can buy?
1) if you have troubles with the one you make, you have to take it all apart again, rip it out and work out how the hell to fix it.
2) Would be much quicker just to buy something and shove it in there and woooooshka it works.
Let me know guys!
Drew
Liberty Driver
Postby Drew » Thu May 26, 2005 7:09 pm
Pyro, you can get an aftermarket u-pipe thingy, that joins the airbox inlet and the scoop thing that bolts to the front frame, but they aren't very free flowing...
Andrew
deafwish
Postby deafwish » Fri May 27, 2005 9:38 am
pyro wrote:bah, too much work, is there just something we can buy?
Let me know guys!
Lazy sod!
I bet your one of those guys who pay the car wash cafe's to wash your car......... :roll:
Ha! :lol:
namzz
Postby namzz » Fri May 27, 2005 9:40 am
0o0o dam thats harsh...
Damo
MY03 WRX Driver
Postby Damo » Sat May 28, 2005 3:26 pm
Hoo-freakin-ray.
I fainlly did it and its great.
Wasn't too hard, and I didnt break a single clip, guess it helps if its not too brittle.
The guide was all I needed, things seemed a little different due to it being a MY03, but didnt take of the plastic arch cover thing, just dettached all of it and folded it out of the way.
First test drive was uninspiring, good not great.
Then took drove it home from the parents house (bigger garage) and was thrilled as the BOV seemed to get louder.
I cant think of a reason for that to be the case, but dammit its true :)
Turbo spool and bov is great, not nearly as loud as an after market though, but nice for me and I can drive past a cop with little to no fear :D
Thanks for the guide!
Can't recommend this enough.
Together with the Rowville exhaust its even more fun to drive.
Infact I am going out NOW! :P
[MET]
Postby [MET] » Wed Mar 22, 2006 7:27 pm
just did it on the STI, and wow! makes cool noises! sounds like a pod on an N/A car but you hear that whoosh and ccshh of the blow off, sweet as love it plus it was near 30c outside about to take it for a spin now its cooler and expect it to be alot louder, literally took 15mins and I guess the CAI still supplies fresh air to the inner gaurd, def going to get a APS in gaurd pod when funds allow it :D
- MARK - VE-SS 6M 6lt -
- SOLD - MY02 STI -
From bugliest STI to toughest SS;)
Mr Corduroy
Silver/Blue WRX Driver
Postby Mr Corduroy » Mon Apr 17, 2006 6:51 pm
Borti wrote:I did the resonator-ectomy to my car, except i removed the box and installed the GP-Moto intake elbow. I think I am going to put mine back on as I plan on upgrading to a new vehicle soon. . .
Does it make the car a lot noiser? Is that why you will bother replacing it? (After all it's pretty had to tell it is missing).
Silver MY05 WRX & Blue MY98 WRX
