DIY Change da Oil!!
tu
TUSPEED
TUSPEED
Re: DIY Change da Oil!!
Postby tu » Wed Jan 07, 2009 3:40 pm
I think the pink STi filters are actually a race only item... they have a higher flow and "high temperature seals"....
http://www.tuspeed.com
kasdave
Blue GDB STI Driver
Blue GDB STI Driver
Postby kasdave » Wed Jan 07, 2009 4:06 pm
Thanks Adam...
STimulated
damo7f
Re:
Postby damo7f » Fri Jan 09, 2009 5:22 pm
rexmang wrote:Um you misunderstood me, you can easily do the oil change while the car is on its wheels.
Agreed. I needed to drive one wheel onto a 50mm thick bit of timber to get the drain tray under the sump, but otherwise there's adequate room to move. I'd have preferred stands, but not really a problem to do without.
subi06NA
Blue Piggy (Grey)
Blue Piggy (Grey)
Postby subi06NA » Mon Feb 27, 2012 7:18 pm
im abit sad that it took me about 90 minutes to change oil... Jacking up a lowered car and undoing a bolt that had been rattled gunned up took the longest time , you get a good feeling after doing work on your car. :roll:
