Cold Air, airbox.. ?
Sharpshooter
Re: Cold Air, airbox.. ?
Postby Sharpshooter » Thu May 29, 2008 8:10 pm
cpitts wrote:Putting the pod in a box will probably reduce it's ability to suck air in an unrestricted fashion.
The upside though is that it shouldn't be sucking hot air at immediate take-off or very low speeds (like dribbling along in peak hour parking traffic). Reality is, once the car is moving, the engine bay air will be replenished cooler air from the front of the car.
I will do the same thing when I get around to it!
Steve at AVO, said my tune wouldn't alter if I put my pod in a box. So I guess there will not be a restriction
Will be making a carbon fibre unit when I get the time
Michael
cpitts
White Liberty SpecB Driver
Postby cpitts » Thu May 29, 2008 8:21 pm
If I know Steve, he probably also said "Don't waste your time, the hot air isn't an issue" ;)
funwin
Postby funwin » Thu May 29, 2008 11:42 pm
GREAT DIY.... but
I tackled this today, but failed :(
i bought the 90mm pvc but after i took the flange out of my airbox my hole was only 70mm so i have to go get some more piping soon.
then when i put it all back together i didnt follow fisher instructions properly :chair:
Fisher wrote:Note to self: remember to plug in AFM cables etc in after use...*Puts in reverse* "oh hey the check engine light is on..wtf...*splutter sounds*" etc :oops:
and then when i was putting it all back together... i broked something? i dunno what it is? help?
can you see that bit that pup with the oil on it that goes to the box thing. well it joins that and then runs up into the bottom of what i believe is my boost solanoid. but now i broke that bit of the box. you can see that its doesnt look connected...
what is it?
how important etc.?
www.nuvismedia.com.au
Nick
MY99 V5 STI Type R Coupe
Nürburgring - 9:49.9 BTG
Sandown - 1:25.17
Winton - 1:40.0002
HH - CW 59.66, CW8 65.02, CST 39.59
Phillip Island - 1:59.01
Calder - 1:05.85
cpitts
Postby cpitts » Fri May 30, 2008 12:07 am
not sure what that connection is, I only took the top off the airbox to do the whole exercise so never got to that part of the engine bay. btw, that metal bit looks like a brace and that's about it. Just to stop wobbling around no doubt.
So long as all the pipes can still plug back in then there'll be no air leaks and it'll start and run fine.
bigtim11
Postby bigtim11 » Sat Apr 02, 2011 11:50 am
Do these fit the GC8's as well? And do you reckon I could just order one through Subaru Parts or are they an american item? I need one ASAP.
2005 WRX Hatchback - Black
cpitts
Postby cpitts » Sat Apr 02, 2011 1:48 pm
Domestic part. Used to be ~$AU10, so now days with the monopoly in Melbourne...... about $300. ;-)
funwin
Postby funwin » Mon Apr 04, 2011 3:27 pm
Subaru docklands got me mine. Tis an rx part. Not very expensive
Nick
Sandown - 1:25.17
Winton - 1:40.0002
Calder - 1:05.85
Chocolate Wheels Driver
Postby Snowy » Mon Apr 04, 2011 11:38 pm
bigtim11 wrote:Do these fit the GC8's as well? And do you reckon I could just order one through Subaru Parts or are they an american item? I need one ASAP.
Yep fit GC8s, ordered mine through Subaru Glen Waverly in Jul '09:
Part Number: 46059FA000 (per my Tax Invoice)
Description: Plug Qtr Panel 55NLIB
Cost: $10.20 (in Jul '09)
