Car Detailing
The STiG
Some say....
Some say....
Re: Car Detailing
Postby The STiG » Sun Dec 28, 2008 10:28 am
This is for all you P-car fans out there...
Enjoy...
Before:
Interior Before:
Interior Clean up
Interior After:
Divine on all the interior carbon pieces and Einszett Cockpit was used to wipe down the interior bits , Leather Master Trio on the leather, Adam's Carpet Upholstery for spot cleaning the carpets and floors
One of my favorite shots!
Prepping:
Brushing away all the bug and tar
Brushing the door jambs with a Swissvax Detail Brush
Wheels and Tires:
P21S Autowash on the tires
P21S Wheel Cleaner Gel on the wheels (Einszett Atomizer Bottle)
Rinse down
Car Wash:
Dan on the Cam Spray
Car was on a charger while we did the polishing
Before and After Polishing (hood)
Before hood shots in different angles
50/50 shots
After SIP and PO85RD
After paint correction on the hood:
Fender before shot:
Fender after SIP and PO85RD
with flash
Final shots with Swissvax Divine as a last step.
Inside:
Outside unfortunately it was cloudy that day, sorry.
Ada///M.
The STiG
Some say....
Some say....
Re: Car Detailing
Postby The STiG » Tue Jan 06, 2009 2:14 pm
Here is some fantastic information for beginners, what it all means and how to go about it.
Hope this helps.
The advent of detailer's clay is an example of why it's important to stay in touch with the innovations made in the detailing industry. New products, chemicals, technologies and ideas are constantly being introduced.
When automotive clay was first introduced there were reports of paint damage due to improper use. With education on correct application methodology this is no longer a problem. It amazes me how many professional detailer’s do not know what detailing clay is capable of, let alone how or why they should use it. For the rest of us who have been using it for ten or more years, we can't imagine being without it
Even new cars that have been setting on a car dealerships lot for a few weeks can accumulate contamination that bonds to the paint surface; don't assume a vehicle that looks good is contamination free. Do a ‘Bag Test’ place some saran wrap or a zip lock bag over your hand and rub across the finish lightly. Every snag you feel is a surface contaminant that the clay bar can remove but you may not be able to see, especially on white or light coloured vehicle surfaces.
Acid rain, road salt, tree sap and airborne contaminants are very detrimental to a vehicles paint film surface. Brake dust or rail dust is very small, almost microscopic particles of steel, iron or their alloys. These particles carry a positive charge (due to friction) while the vehicles they land on are carrying a negative charge. The vehicle surface becomes a magnet, attracting and bonding the ferrous metal particles to the vehicle surface.
Regardless of how clean you think your paint is there are still bonded contaminants on the paint that you need to remove before pre-wax cleaning, polishing or applying a protection to your paint film surface. Use automotive detailing clay to remove; road dirt / grime, bituminous resin (tar) grease, tire rubber, bug debris, bird excrement, tree resin (sap) rail and brake dust, paint over spray, hard water (mineral) deposits, industrial fall-out (IFO) road salt (small particles become imbedded and bond to the surface) if the paint has the slightest amount of bonded contaminants, even a wool pad will skip and hop
Moisture when an area of metal has a positive charge and another has a negative charge; water acts as an electrolyte,, temperature and ozone (air) create a corrosive chemical reaction (See also Reactivity); corrosion is caused allowing current to flow between these areas. During this process the metal absorbs oxygen from the water and forms iron oxide (rust).
The corrosive chemical compounds generated then proceed to etch (corrode) the clear coat, penetrating and spreading the corrosives through the paint film system (and the sheet metal), which results in erosion of the paint surface, that shows on the surface as tiny rust spots (rust blooms) This is most noticeable on light coloured paint surfaces (especially white)
(See also Acid Rain, Industrial Fallout (IFO) Corrosion, and Decontamination)
In 1990, Tadao Kadate of Japan is acknowledged as the inventor of an automotive clay resin that exfoliates vehicle paint surfaces, it’s the first product to safely, instantly and cheaply remove airborne bonded contaminants from delicate automotive paint surface. Clay bars are used in the detailing, automotive reconditioning and auto body paint and repair shop professions to remove paint over spray, tree sap and industrial fallout from the cars painted surfaces. It also works on glass, plastics and many metals. First used by Japanese auto manufacturers on vehicle production lines and then auto body repair shops, the technology was passed on to the US market in the late ‘90’s.
Automotive clay is not a replacement for polish or a compound; it is a pliable, petroleum resin product, Polybutene PB-1 (Polyisobutylene) containing a mild abrasive(s) i.e. kaolin, silica sand, calcium carbonate, alumina, ceramics quartz and also silicon carbide that polishes and exfoliates bonded surface contaminants by shearing, which is then encapsulated by the clay resin. These abrasives are extremely small with an average particle size of 1- µ (micron) dependant on the aggressiveness required, mixed in with a powdered synthetic detergent.
The clay bar may not totally remove rail dust, but it will exfoliate the protruding particles. It will, however, easily remove surface contaminants i.e. tree sap or paint over-spray. Usually only the horizontal paint surfaces require detailer’s clay treatment, as it is these surfaces that contaminants tend to land on and adhere too, you should evaluate any vertical surfaces and if need be, clay them. It can be argued that a polish or compound will do the same thing; problem is that they not necessarily remove surface contaminates but just ‘round-off’ the edges, whereas clay will remove the surface contaminants and a percentage of the applied wax /polymer.
Note: you may have to remove minor surface marring caused by the clay
This thin film of lubrication (see Detailer’s Clay Lubrication) provides a safety barrier that enables the clay to hydroplane across the surface. In other words, the clay is riding on a micro-thin film of lubrication between it and the paint surface removing the (protruding) surface contaminants by abrasion and encapsulation by the malleable clay. Without lubrication the clay will abrade the paint surface much like a wet-sanding block and will produce significant fine surface marring
Most manufacturers colorize (these colours vary by reseller) the clay to identify differing abrasive strengths (this is accomplished by varying the type, amount or particle size of the abrasive used) i.e. Green Clay is a very fine abrasive clay, Clay Magic® Blue is a medium - fine abrasive, whereas the Red is a medium - heavy abrasive, it is also very effective for the removal of paint over-spray, if the over-spray is particularly heavy, you may want to seek the assistance of a professional.
1. Fine- clay that abrades or shears light surface or imbedded paint contamination and encapsulates it. This grade of clay can be used on a regular basis for paint surface ‘maintenance’ Sonus SFX or Pinnacle Ultra Fine Detailing Clay - Autopia Car Detailing Forum - Car Detailing or
Pinnacle Ultra Clay -http://www.pinnaclewax.com/piulfigrdepo.html
2. Fine - Medium-clay that is used to remove heavier surface contaminants (bird excrement and bug reside) it is slightly more abrasive than the fine grade and abrades the paint surface, while the clay encapsulates it
Clay Magic® - Clay Magic detailing car clay and Auto Magic specialty products
3. Medium to Heavy duty- clay that is used to remove paint over-spray; it contains slightly stronger abrasive or larger particles that abrade the paint, while the clay encapsulates it. Clay Magic®
Aggressiveness (on a scale of 1 to 5)
1 Clay Magic® - Red- very aggressive; most surface marring - 5/5
2 Top of the line purple- slightly less aggressive - 4/5
3 Clay Magic® -Blue- less aggressive; less marring - 3/5
4 Mother's - Yellow- 2/5
5 Sonus Ultra Fine -Green- 1/5
There are only a couple manufactures of clay and patents protect the technology, with some subtle difference
in consistency and firmness, a recent court hearing found components of the “elastic clay” to be a patent infringement and the judge ordered sale of the product to be halted. (In the United States, Auto Wax Company Inc. (now owned by Illinois Tool Works Inc.) owns the US patent rights (No. 5,727,993) and reads thus-
"Conventional compounds comprising an elastomeric resin mixed with abrasives used to remove protrusions, projections, and/or strongly adhered foreign matter from vehicle surfaces"
Auto Wax owns six patents relating to clay products and provides private label clay too many of the detail industry’s leading companies - Clay Magic detailing car clay and Auto Magic specialty products As a result, all of the Polybutene (Polyisobutylene) or plastic clay being manufactured now comes from the same factory in Japan, which as the only patent holder has a monopoly on the market. Meguiar's, Mothers, Sonus, Zaino, et al get their clay either from Japan (Source Chem. Inc. one of Japan's biggest clay manufacturers) or from a US licensed manufacturer.
But the formulation can vary significantly, mainly;
1.Density or plasticity
2.Abrasive particulate size
3.Abrasive used (i.e. silica sand, calcium carbonate, alumina, ceramics, or silicon carbide)
4.Abrasive density ratio (abrasive content to clay)
5.Colour (to identify differing abrasive strengths)
Other Uses
Detailer’s clay can also be used on glass surfaces (exterior) to remove heavy road film, bug deposits and surface water spots; it seems to outperform even the best window cleaners. Clay will safely remove stubborn embedded brake dust, tar and road film from original equipment manufacturer (OEM) wheel surfaces (detailer’s clay is not recommended on wheels that do not have a clear coat or powder coat finish.
Alternative clays -
1. Zymol Lehm-Klay 2 (contains quartz and chalcedony abrasives) - Zymol Car Care Products & Accessories
2. Sonus SFX Ultra Fine Detailing Clay - Autopia Car Detailing Forum - Car Detailing
3. One of the factors that make Optimum Opti-Clay work better than Clay Magic is that it is based on cross linked polybutene resin which is more durable, more elastic, and has a great deal more adhesion properties than the resin used in Clay Magic (0nly available outside of US / Japan).
Alternative product- Hi-Tech Body Sponge™ this innovative rubber polymer product safely and easily removes overspray, water spots, tree sap, rail dust, bugs and other bonded surface contaminants from the surface of automotive paint, glass, mouldings and plastic, may be used with any kind of lubricant. Sponge retains soap and water and releases it as a lubricant when gently squeezed while gliding over the surface. Unlike detailer's clay this product can be cleaned by simply rinsing off the accumulated contaminates with water or in a soap bucket. Accidentally dropping it on the ground is not a problem. Just rinse the sponge pad clean and you're ready to keep using it. Easy grip sponge allows for sturdy and controlled handling, can be used up to 30 times before needing to be discarded. Hi-Tech Body Sponge™ - Auto Detailing Supplies
Frequently asked questions (FAQ)
a) Does my paint surface require the application of detailer’s clay? – is the paint surface showing one or more of the following; coloured or yellow stains, water marks (spots) black metallic coloured flecks, a rough texture, etch marks (concave depression) oxidation, bug or bird excrement, place some saran wrap or a zip lock bag over your hand (‘bag test’) and rub across the finish lightly. Every snag you feel is a surface contaminant that the clay bar can remove but you may not be able to see, especially on white or light coloured vehicle surfaces.
b) How often you need to clay depends on your environment and how you maintain your car see ‘bag test’ above. If you find the need to use detailer’s clay on a regular basis use mild clay
c) Using automotive clay- to remove surface pollutants and abrade the debris from the paint film surface leaving behind an ultra-smooth surface that will make your paint protection adhere better and improve its durability. You can use detailing clay on any smooth, hard surface, including glass (exterior) to remove heavy road film, bug deposits and water spots, and chrome. Do not use on clear plastic, such as headlight lenses as it may cause ‘fogging’. The best way to describe the proper method for using detailer clay is to use plenty of the lubricant and aquaplane the clay bar over the surface in straight-line motions, in the direction of airflow and using light hand pressure, you should hear a slight noise and feel some resistance; this is the contaminants being abraded.
d) If I’m going to polish the car with an abrasive, do I still need to use detailer’s clay?
One good reason to clay before you polish; polishing can result in smoothing and rounding the surface contamination it making it significantly harder to remove later. Although a polish / compound will remove the contamination there is a risk is that the abrasive particles will become embedded in the foam pad, which will cause surface scratches / marring by making the foam /polish more abrasive than necessary
Inspect the clay surface often and fold (knead) clay to present a clean surface to the paint to avoid scratching; when the clay surface becomes really soiled (it becomes more difficult to find a clean surface by kneading, discard and use fresh clay. Do not over use a clay bar; expect approximately 5-10 uses from a single, 8 oz. bar
Before you clay and after you wash the paint surface, you’ll need to remove the old paint protection first so you can get down to the bare paint where these contaminants have attached themselves. If you’ve never clayed your car before, chances are that there are contaminants being protected underneath your previous wax or sealant coat, that’s why you need to remove the old protection before you clay.
I do not recommend using a harsh dishwashing detergent such as Dawn, as they tend to dissolve oils and can prematurely dry up rubber moulding and trim. I recommend using a d-limonene (citrus) based paintwork cleanser. (P21S Total Auto Wash) Once you remove the old paint protection then proceed to the paint surface preparation process; detailer’s clay, polishing, and then applying a surface protection.
Application Methodology
•Select the appropriate abrasiveness of detailer’s clay (i.e. Ultra-Mild, Fine, Medium to Heavy)
•Divide the detailer's clay into several equal pieces and knead into a ball to ensure pliability
•Take one of the pieces and flatten it out into a circle, approximately enough that it will fit onto two or three fingers
•Spray a 2-foot by 2-foot surface with a lubricating solution, ensure that the surface being clayed is always wet (important enough to restate- ensure that the surface being clayed is always wet)
•Inspect the clay’s surface often, knead /fold to provide a clean surface as necessary
•Glide the clay across the area in a front to back straight-line ( in direction of airflow) aquaplaning type motion, Use long strokes without lifting the clay from the surface
•Use a light to medium even pressure until the surface becomes smooth and silent.
•If the Clay is streaking on the paint, you need to apply more lubricating solution, it is better to over lubricate the paint film surface than let it dry-out
•To avoid wasting detailer's clay because you probably will drop it, place a towel on the ground under the area you're claying so the clay will fall onto the towel without picking up gravel etc.
•If you drop the clay on the ground do not try to clean it, discard it or it may cause micro scratches in your paint film surface.
•Rinse of any clay residue and ensure there is no more contamination to remove
•Move onto the next two-foot by two foot square area and repeat the process.
•Once half the section is completed turn the clay over to a fresh, clean side and completes the remaining section.
•Check the surface of the clay often, once it becomes contaminated fold to a clean surface.
•Wash, rinse and dry each section and ensure (‘bag test’) all imbedded surface contaminants have been removed before moving on to the next panel / section
•I would go over the paint surfaces again with the clay to ensure nothing was missed
•When complete wash, rinse and thoroughly dry the vehicle.
•The surface is now ready for a paint cleaner to ensure a pristine surface
•Any wax that was on the paint surface has been removed, so you should re-new the paints protection system
(See also Paint Decontamination / Neutralisation)
Detailer’s clay - can also be used on glass surfaces (exterior) to remove heavy road film, bug deposits and surface water spots; it seems to outperform even the best window cleaners. Clay will safely remove stubborn, embedded brake dust, tar and road film from original equipment manufacturer (OEM) wheel surfaces; detailer’s clay is not recommended on wheels that do not have a clear coat or powder coat finish.
e) For a pristine paint film surface- after the application of detailer’s clay use a paint cleaner (Zaino ZPC Fusion Dual Action Paint Cleaner – (http//: Zaino Store or Klasse All-In-One (http//:AutoGeek.com Automotive Super Site) to ensure the surface is clean and the sub-surface is free of any grease or other residue, ready for polishing and the application of a sealant and / or Carnauba wax surface protection. The paint cleaner’s suggested above can sometimes be used instead of detailers clay if the ‘bag test’ doesn’t reveal contaminates but the surface looks ‘soiled’ use a chemical surface cleaner (especially on light coloured paint)
f) How it works- detailer’s clay is formulated to remove surface contaminates from the paints, it contains abrasives (i.e. silica sand, calcium carbonate, alumina, ceramics, quartz, or silicon carbide) in an applicator (the malleable clay bar) the clay lubricant is doing the same thing for the clay's abrasives as the oils in a polish, which is providing surface lubrication. Contrary to popular belief it does not pull the metallic particles from the paint surface. The abrasives 'shear' the surface contaminates (i.e. the top of the metallic particle leaving the rest imbedded in the paint, allowing it to continue generating corrosion damage) the sheared particles are encapsulated by the clay. Clay being an abrasive product will remove a percentage of both natural and synthetic wax and most polymer sealants, therefore a paint surface protection should be applied after use.
g) Acid neutralizing wash - I would strongly recommend an acid neutralizing wash followed by a corrosion inhibitor on an annual or semi-annual basis. You will find that a proper acid neutralizing wash opens the paint fissures (pores) and will release most of the imbedded ferrous oxide deposits and the remainder comes off very easily by clay encapsulation. These systems will produce a better finish on the paint surface than is possible with detailer’s clay alone and is also the only solution that addresses acid rain, industrial pollutants, and tree sap etching as well as other polyurethane clear coat concerns
Products-Neutralisation / Decontamination Systems; A, B C Decontamination System – http//:Automotive International - Valugard Product Line
Finish Kare 1119 / 883 Paint Decontamination - Finish Kare FK1 1119 / 883 Paint Decontamination System
Surface scratching-
When automotive clay was first introduced there were reports of major paint damage due to improper use. With education on correct application methodology this is no longer a problem. Like all abrasive products you need to select and use; the appropriate grade (abrasion ability) proper / adequate lubrication, the correct application methodology, exercise due care and diligence. Detailer’s clay will cause surface marring or scratching on a paint surface due to the following;
(a) Using an unnecessarily aggressive grade of clay
(b) Using insufficient or an inappropriate lubrication on the paint surface
(c) Too much hand pressure applied, try a 3-inch ‘flat pancake’ shape held between two fingers
(d) Trying to ‘clay’ too large an area (should be 2’ x 2’<)
(e) The ambient temperature is unsuitable; too cold (50oF <) and will not allow sufficient kneading of the clay bar to ensure a 'clean' surface, too hot (>75 oF) the lubrication dries out and the clay becomes unstable
(f) You drop the clay and pick up road dirt / grit.
(g) Read the manufacturers' directions for the number of uses of their clay bar. Do not over use a clay bar; expect approximately 5-10 uses from a single (8 oz.) bar
To correct any surface marring / light scratching use a mild polish (Zaino PC Fusion Dual Action Paint Cleaner Swirl Remover or Menzerna Final Polish II) using a White or an Orange LC pad, speed 5 – 6
(See also Detailer’s Clay Lubricant)
Detailers Clay Lubricant:
The critical safety factor is adequate lubrication; most clay retailers supply their detailing spray (QD) as a lubricant, the problem with many of them is that they contain some form of solvent or alcohol, which may cause the clay to dry out. To provide sufficient lubrication the surface must be thoroughly saturated, problem is that a solvent dries out the clay, which could cause surface marring or cause it to disintegrate, or breakdown and become soft leaving streaks on the paint surface. Some car wash concentrates will also cause some of the same problems due to the synthetics, detergents and / or solvents used.
To ensure adequate surface lubrication and avoid surface marring use a product (Optimum No Rinse (ONR) - – http//:Top of the Line Auto Detailing Supplies) that contains a surfactant to ensure that any dirt/grit / metal debris is encapsulated and held in suspension and can be rinsed away
The best way to describe the proper method for using detailer clay is to use plenty of the lubricant and aquaplane the clay bar over the surface in straight-line motions. A mild liquid soap (Woolite™) works as a lubricant and is gentle enough that it will not adversely affect either the clay, vehicle paint or trim using a 5:1 solution of distilled water / Woolite™. As an alternative use a 16:1 solution of distilled water and a pH suitable car wash concentrate (Zaino Z-7 Show Car Wash, pH7.0) in a 16 ounce spray bottle, a lubricant made for clay Zymol Lehm-Lube 2 - Zymol Car Care Products & Accessories
Storage – Detailer’s clay should be stored in a cool (range- 50- 75oF) dry place, store your clay in a plastic baggie or a plastic soap travel case. Mist the clay with a Quick Detailer (QD) and place the piece of remaining clay in the storage container, and close the lid or seal tightly.
(See also Using Automotive Detailers Clay, Section 04)
Ada///M.
The STiG
Some say....
Some say....
Re: Car Detailing
Postby The STiG » Sat Apr 11, 2009 11:26 pm
WASH&DRY
Foam Gun II
Chemical Guys Citrus Wash and Gloss
Two bucket method/grit guards
Sheepskin Mitts
Detailed Image Microfiber Towels
CLAY
Clay Magic Fine Grade Bar
Meguiars Quik Detailer
PAINT CORRECTION
Merzerna SIP/Orange Pad
Merzerna 106FF/White Pad
LSP
Chemical Guys Jet Seal 109/Blue Pad
PROTECTION
Dodo Juice Purple Haze Wax
MISC
Eagle One Tire Cleaner
Mothers Metal Polish
GEAR
Porter Cable 7424
Fluke 61 Infrared Thermometer (to see the difference in temp)
Sony W120
Detailed Image Microfiber Drying Towels
BEFORE
AFTER
HOOD
TRUNK
Drivers door, BEFORE
AFTER
HOOD
Drivers Front Fender BEFORE
AFTER
top of trunk, BEFORE
AFTER
Ada///M.
The STiG
Some say....
Some say....
Re: Car Detailing
Postby The STiG » Mon Apr 13, 2009 10:21 am
The wife's daily driver. Unfortunately or fortunately it really has been cared for since November, busy schedule, illness, family, work you name it.....its strange though however bad the salt and snow was this season the crystal rock seemed to hold strong for the season.
So a good cleaning and polishing with a coat of wax was due, as well as a complete interior clean up, 1 6 year old and boy oh boy....
Since it was still early in the morning and cold I decided to go for the interior first.
Before:
Cleaning the interior up with vac, brushes, Einszett Cockpit
Some before and after interior shots:
After a nice cleaning with Cockpit
Driver's door armrest:
Before:
During:
After:
The alcantara clean up and protection process.
before (the white crusty stuff comes out or a 6 yr old's nose)
the first step was to vac it out then in the pics below the Leather Master Foam Cleaner was used with a damp applicator pad and Foam Cleaner was applied directly on the app pad. In circular motions the product was applied, then let dried.
The mf towel was used to wipe off excess and to assist the drying process
Door panel was cleaned and protected
After interior shots:
Exterior:
Before shots:
Presoak
Foam canon with Adam's Car wash
After claying we did measured the paint
After Menzerna PO85RD (as this car sits outside this was not fully corrected i would say we did about 85%)
Exhaust before
Swissvax Metal Polish
After:
Engine before:
Engine after:
Yes Swissvax on the carbon fiber covers
After shots:
Drove it to a nice empty parking spot for some more pictures.
Ada///M.
The STiG
Some say....
Some say....
Re: Car Detailing
Postby The STiG » Sat Aug 29, 2009 3:17 pm
HONDA NSX
Posting only the details with major correction. too busy with work. unless yall want me to post 1step polishes, new car preps, wash/wax details (which are boring). coming up to the plate was now my 10th black car in a row. Vehicles history, owner had it for 5 years and kept it cleaned and garaged kept (only 22k miles). he hasnt driven it in about a year. before storing in the garage, he had it detailed by a "pro detail" shop :facepalm: I found lots of residue in cracks, jambs, etc. Mind you, this guy is very particular about all his cars. As the go to detailer in my area for the local car clubs, i had to treat his NSX as i do with all cars, like its mine and also to keep my reputation. He wanted it to be prepped for a show and i took on the job. my initial response was about a day and half for the detail since he said it was previously detailed and it hasnt been driving in 9 months so i said itll be an easy one. i was wrong. on to the detail.
PROCESS:
ENGINE
P21s TAW
303 Protectant
WHEELS/WELLS
P21s Gel
Megs GC
EXTERIOR
CWC/Foam Gun, Rinse
CWC, Megs GC 2BM, Rinse
CLAY
Megs White
ONR Lube
IPA Wipedown
Rinse, WW MF Towel
CORRECTION with PC 6" & 4" pads
PG/Orange for Spot Treatment
IP/Orange
106FA/White
PO85RD/Blue
SEALANT
JetSeal109/Blue
LSP
its black so of course its getting Purple Haze
INTERIOR
Leatherique Twins
303 Fabric Guard
Wet/Dry Vac
FINALS
Stoners IG/Aquapel
No Wheel Sealant per request
OPT Wheel Gel
OPT QID
Day1. Thursday Evening (Engine, Interior Dust/Wipedown)
For Show or Not, attention to detail is key
Day2. Morning
Wheels. Being very careful not to wash over spoke sticker and stickers in barrel. i washed around it
Ready for wash
CWG dwelling and dont forget behind the plates
Started with all fresh new supplies. After claying found no contamination
50/50. rear portion of the passenger door after IP & 106FA
brought it outside to check it (right side)
since i had it outside, i took a few shots of the rest of the car.
YIKES!
brought it back inside now that i found my combo. started on the passenger side and forgot to take a before picture. this is the drivers side pillar
passenger side after 106FA
FRESH Pad
If this aint 100% corrected, its sure da mn close!
lets ask the sungod. (those arent trails, just weird reflections)
Fingernail deep RIDs that i couldnt get out. now if it this was on the paint yeah, i could fix it but i wasnt going to grit it just for that. but trust me, the rest of the taillight strip is perfect :)
precaution i take when someone has the wheels i want. i just cover it so i wont be tempted to steal it.
JK> less risk of scratching the Volks.
I did one pass of PO85 wit bring out that gloss even more.
Owner came by to check on the progress. he left with a smile on his face (=
black FTW
After ONR Wash and IPA wipedown, checking for washed induced swirls.
Day2. Evening. Inside for Sealant/Wax/Interior
During the curing times of the sealant and wax, the leather and the rest of the interior was detailed
Notice how Leatherique lifts all the dirt. pure dirty brown
Day3. Morning ready for pickup. Show was in a few hours. Final touches to glass and tires.
under front hood *spare tire is out
engine bay
rear pass fender
trunk
roof
passenger door
hood up
drivers side
left drivers side mat in trunk so he can place once he gets to car show. also left a few MF towels in ziplock bag for the show
trunk
at the show
yaay you made it to the bottom.
as always thanks for viewing
Ada///M.
The STiG
Some say....
Some say....
Re: Car Detailing
Postby The STiG » Sat Aug 29, 2009 3:30 pm
Let's get the interior shots in first:
Cleaning up the alcantara and protecting it
Final shots
Wash and Prep:
Wax build up
Etching in the paint more wax/old polish build up
Pre soak and cleaning up trim
Cleaning up the wheels (not much needed)
Engine Before
Cleaning the engine bay
All Purpose wash
Claying
Masking
Testing the area for paint thickness and plan of attack
Polishing
Before shots of passenger door
Different angles
Halogen after PG/SIP/PO85RD
Fenix light on panel after PO85RD
After all that polishing.....
DUST!
After polishing before the rinse down (no wax)
Rinse down:
Engine Before /After
Swissvax Divine
Applying Divine
Ada///M.
Removing Wax
Final touches
Swissvax Autobahn on the wheels
Black Wow on the trim
Gummi on all the seals
After Gummi
After shots
Ada///M.
The STiG
Some say....
Some say....
Re: Car Detailing
Postby The STiG » Sat Aug 29, 2009 4:06 pm
Outside
Final shot
Ada///M.
The STiG
Some say....
Some say....
Re: Car Detailing
Postby The STiG » Sat Nov 28, 2009 10:01 am
Bentley Flying Spur
Phil, hard at work once again, seriously awesome and thought everyone would enjoy.
As the title states on this one this was one pretty trashed Bentley, for the most part I wasn't expecting anything this bad. The customer wanted it fixed and didn't really mind how long it took or how much. Again we couldn't believe how bad it was, until we saw it in the direct sunlight.
We did the normal prep work, wash, wheels, clay, etc. For the paint correction we enrolled Menzerna Power Gloss Compound with an Uber Yellow Pad, followed by Menzerna Super Intensive Polish with an Uber Green Pad, finally we finished with my favorite Menzerna PO85RD. As a last step we gave it a coat of Swissvax Divine. Enjoy!
Let's start with some before shots in the direct sunlight at drop off.
Ada///M.
The STiG
Some say....
Some say....
Re: Car Detailing
Removing Plates
Pre soak with Einszett Blitz (bug and tar)
Before shot of the wheel
Ada///M.
The STiG
Some say....
Some say....
Re: Car Detailing
Postby The STiG » Sat Nov 28, 2009 10:02 am
Ace Powerstick used to clean up the inner wheels
Washing off the Blitz
Washing the car
Ada///M.
The STiG
Some say....
Some say....
Re: Car Detailing
Postby The STiG » Sat Nov 28, 2009 10:03 am
Clay
Tommy claying the Bentley
Wheels all cleaned up
Tommy rinsing up the car after the clay
After shot of the wash and clay, massive paint correction ahead of us
Dan on the Metabo with an Uber Green Pad and SIP
Ada///M.
The STiG
Some say....
Some say....
Re: Car Detailing
50/50 shots after the 3 steps!
Spot checking with the Fenix
Then checking the car again outside
Finishing out with Menzerna PO85RD
Ada///M.
The STiG
Some say....
Some say....
Re: Car Detailing
Postby The STiG » Sat Nov 28, 2009 10:04 am
Tommy pulling off the masking off the windows and trim
Swissvax Divine
After shots
Ada///M.
cpitts
White Liberty SpecB Driver
Re: Car Detailing
Postby cpitts » Sat Nov 28, 2009 1:24 pm
How shocking was the Bentley! :o
billyl
Re: Car Detailing
Postby billyl » Sat Dec 12, 2009 9:39 pm
wish my rex could look like them all shiny :(
bluddy great job there done there punk
2006 wrx cs9 wr blue
The STiG
Some say....
Some say....
Re: Car Detailing
Postby The STiG » Fri Jul 16, 2010 3:52 pm
Garage king : Ferrari F430 Spider. In very good shape but with a need of claybar treatment and a refresh .
The nose was all cover by a nice bug collection.
Wheels was clean with car soap and seal with optimum car wax, tires got m40.
Interior was slightly used.
Being an convertible I address the paint that get`s under the top cover. Was wash with quick detailer , and clay with meguiar`s white clay bar and onr quick detailer. The leather seat headers was treated with meguiar`s D180. Once the top is on is hard to have access to it so is better to have it done when the car has the top open.
Green tape was use to cover the engine grills/glass , and rubber trims.
Ada///M.
The STiG
Some say....
Some say....
Re: Car Detailing
Postby The STiG » Fri Jul 16, 2010 3:53 pm
A pic of the setup after was polish with m205 and polish pad using an DA and 2 coats of optiseal for protection.
The top was clean and treated with 303 fabric guard. The rear plastic window was in bad shape , stained and water spots , a bad visibility.
I polish by hand with plexus on a microfiber towel . interior and exterior.here are some before after shots.
After all this I address a 4in light scuff on driver door , I couldn`t get it on cam , and another 4-5in scratch on the rear bumper.
Ada///M.
The STiG
Some say....
Some say....
Re: Car Detailing
Interior was dust wipe , leather treatment was applied on doors and seats , follow by some vaccum action and scotch-guard carper protectant on floor mats.
All the top was cover with plastic wrap , all sensitive areas got green tape for protection and easy clean up. Paint was polished with meg205 and foam polish pad with DA and seal with 2 coats of optiseal. Car still cover but after polish step.
Image A nice swirl free view:
Ada///M.
The STiG
Some say....
Some say....
Re: Car Detailing
Postby The STiG » Fri Jul 16, 2010 3:54 pm
AFTERS:
Ada///M.
The STiG
Some say....
Some say....
Re: Car Detailing
Ada///M.
