DIY - Apexi AVCR Installation
Age
S204 Driver
Postby Age » Sun Jul 10, 2005 8:59 am
-The purple wire should be connected to engine RPM if you want to use Self/Learning and RPM based settings
- The purple wire can be connected to the injector signal wire to monitor fuel injector duty cycle
So it's up to you what you want. :wink:
NGUY
Blue GD Wagon Driver
Postby NGUY » Tue Nov 08, 2005 7:56 pm
Is there any way of changing the reading from Bar to PSi?
Clutchcargo
Postby Clutchcargo » Tue Nov 08, 2005 8:32 pm
No, but its really not that hard.
Approximately:
1 kg/cm = 14psi
1.1 kg/cm = 15.5psi
1.15 kg/cm = 16psi
1.2 kg/cm = 17psi
1.25 kg/cm = 18psi
1.3 kg/cm = 19psi
NGUY
Postby NGUY » Fri Nov 11, 2005 11:10 pm
I'm getting around 1.09kg/cm, so what does that equal to?
Clutchcargo
Postby Clutchcargo » Sat Nov 12, 2005 7:13 am
^^^^ Ready Reckoner says about 15 psi...
Or http://www.mn3s.org/conversions.html is a good converter.
Look in real terms, the difference between 1.05 and 1.1 isn't going to blow your engine if the tune is conservative.
DWRX
Postby DWRX » Wed Sep 13, 2006 8:54 pm
Attempting to install mine this weekend too... Just a bit worried about HACKING my ashtray, but it seems to be the best place for the AVCR...
MY05 WRX Hatch 164.2kw on 16psi
Maters
Re: DIY - Apexi AVCR Installation
Postby Maters » Mon Jan 11, 2016 10:32 am
I really wish this pictures worked, I need them so badly as this is the best tutorial I've found so far and I'm still having trouble..
Return to “DIY Guides”
