Fading / Yellowing Headlight Lenses
TSUBi
Postby TSUBi » Thu Oct 04, 2012 9:30 am
EDIT 17/8/13: see http://forum.wrx.com.au/viewtopic.php?f=46&t=78333
Tried this product on the wife's 05 Astra:
Results: Was 'ok', but not great. Didn't give the results I was hoping for.
Has anyone successfully tried other methods to remove oxidation/yellow scum from headlight lenses?
I'm thinking about trying the 'toothpaste' method seen on youtube.. Got nothing to loose, except a tube of toothpaste ~$2-3..
Will post up some before and afters :)
Current: MKV GTI Golf & Audi A3 8P
Previous: 04 WRX, 99 WRX, 98 WRX
bigtim11
Re: Fading / Yellowing Headlight Lenses
Postby bigtim11 » Thu Oct 04, 2012 10:51 am
Meguires PlastX, way batter than any headlight restoration kit.
I've got a full bottle of it if you're local and can try ;)
2005 WRX Hatchback - Black
Sean47
Blue MY09 WRX Driver
Postby Sean47 » Sun Jan 06, 2013 7:17 pm
We used to use transmission fluid with a rag and it worked on a ford falcon the last time.
zacsprint
Silver GC8 Driver
Silver GC8 Driver
Postby zacsprint » Sun Jan 06, 2013 8:21 pm
I used the same product, but it didn't last very long and in the end it was better to just replace the headlights with new ones. I also have plastic headlight protectors on the Suby now to avoid the problem.
Subaru MY00 WRX GC8-The Classic Shape
Postby Lupin » Sun Jan 06, 2013 8:26 pm
You can polish them all you like. Unless you re apply the uv coating they will just yellow again.
Sean47
Postby Sean47 » Tue Jan 08, 2013 9:28 pm
Lupin wrote:You can polish them all you like. Unless you re apply the uv coating they will just yellow again.
I think you are spot-on about the coting and once this is gone the plastic starts to fade.
