Camera mount
Alpha Dog
Blue MY06 STi Driver
Camera mount
Postby Alpha Dog » Mon Apr 25, 2016 9:00 pm
Hi - would someone with experience in scrutineering comment in this please:
Will this be accepted ?
FWIW that plastic light cover is gonna break before the camera comes loose - the adhesive is 3M permanent. I've used the same to keep the cover in place.... i.e. its glued in.
Pleiades
Re: Camera mount
Postby Pleiades » Tue Apr 26, 2016 9:15 am
Not by me.
It needs some form of leash, cable tie as secondary restraint.
Whilst your statement may be true about strength of plastic and glue, it doesn't look it.
Sent from my iPad using Tapatalk
Alpha Dog
Re: Camera mount
Postby Alpha Dog » Tue Apr 26, 2016 11:55 am
Thanks for the reply. Just to be clear...if I added a tether like a nylon rope to the passenger grab handle, would that fly? (A steel cable would be too heavy and is likely to wobble the camera around).
If it's at all borderline I'll ditch the idea and go with a windscreen suction cup mount which was ok at previous events.
Thanks.
Photo credit: Joel Strickland Photographics - thanks Joel!
neptune11
Re: Camera mount
Postby neptune11 » Tue Apr 26, 2016 12:59 pm
Only one to find out Scotty...
I'm actually looking at doing the same thing!! Just mount the camera after scrutineering!!
MY 11 WRX Hatch
WRC Blue
#Tuned & Serviced by Got it Rex
#Upgraded parts by Tuspeed
#Steering & Suspension by Trutrack
#Engine rebuild by Top Torque
blackrex
Black BMW M6 Driver
Black BMW M6 Driver
Re: Camera mount
Postby blackrex » Wed Apr 27, 2016 11:37 am
Alpha Dog, the rope would be to long, the reason for the tether is to keep the camera controlled and minimise the amount that it can move around the cabin in case the primary mount fails, having it on a 1m long rope will not fulfill that requirement. I have a full cage in my car, with motorsport mounts for the cameras, and I still need to have them tethered. I use a 4mm cable tie around the case (as the case locking mechanism also needs to be secured) as they are relatively cheap to cut off each time I get the camera out, that I then connect to the cage by a 5mm cable tie.
Neptune11, if you get caught doing so, you can be excluded from the event.
If you are not sure if the mount is strong enough, hang a load of 1kg off of the mount, this is the equivalent of the mass of the camera and mount being exposed to a 5G load (relatively slow speed impact), I would say that that mount will fail.
"The problem with socialism is that you eventually run out of other peoples money." Margaret Thatcher.
TINSTAAFL
KuRT12
Re: Camera mount
Postby KuRT12 » Wed Apr 27, 2016 1:57 pm
I was told by the scrutineer at the last event i attended (PIARC) that all objects need to withstand 25g of force, which means suction cups are not allowed (even with a tether).
So i was told to remove my camera mount.
I have not been able to locate anything to back this up in the CAMS schedule though.
MY '12 SWP WRX STi Spec. R Sedan
Sandown 1:20.48 - Winton 1:35.19 - Wakefield 1:06.84 - Phillip Island 1:44.96 - Broadford 1:03.80 - SMSP Gardner (AD08) : 1:48.05
blackrex
Black BMW M6 Driver
Black BMW M6 Driver
Re: Camera mount
Postby blackrex » Wed Apr 27, 2016 2:16 pm
Make that a 5kg load then to test the mounts! No external mounts are allowed either.
TINSTAAFL
Alpha Dog
Re: Camera mount
Postby Alpha Dog » Wed Apr 27, 2016 8:39 pm
OK
118g x 25G = 2.95kg
3.1kg
No problem as I said.
4.8 kg
:coffee:
blackrex
Black BMW M6 Driver
Black BMW M6 Driver
Re: Camera mount
Postby blackrex » Thu Apr 28, 2016 9:28 am
They have obviously made those light fittings stronger then in the GC8's then! Mine used to fall out with only a light amount of load.
TINSTAAFL
Pleiades
Camera mount
Postby Pleiades » Thu Apr 28, 2016 10:17 am
Yep Black has it right.
A constant force does not have same effect as an impact.
Also your hanging spuds are working in a vertical plane not horizontal ;-p
Though i do like your calculations.
Now several clubs are adding a note to scrutiny sticker or separate sticker to say approved camera.
Pit Out people will kick you back if it is not there.
Now if you are warned at scrutiny and/or briefing or Supplementary Regs about doing that, the CoC <waves ;-) > will not take it well.
Return to “Public Club Motorsport Discussions”
