Postby blackrex » Wed Apr 27, 2016 11:37 am
Alpha Dog, the rope would be to long, the reason for the tether is to keep the camera controlled and minimise the amount that it can move around the cabin in case the primary mount fails, having it on a 1m long rope will not fulfill that requirement. I have a full cage in my car, with motorsport mounts for the cameras, and I still need to have them tethered. I use a 4mm cable tie around the case (as the case locking mechanism also needs to be secured) as they are relatively cheap to cut off each time I get the camera out, that I then connect to the cage by a 5mm cable tie.
Neptune11, if you get caught doing so, you can be excluded from the event.
If you are not sure if the mount is strong enough, hang a load of 1kg off of the mount, this is the equivalent of the mass of the camera and mount being exposed to a 5G load (relatively slow speed impact), I would say that that mount will fail.
