Ask your turbo questions here...
j.l.c
Re: Ask your turbo questions here...
Postby j.l.c » Fri May 22, 2009 2:22 pm
Steve,
I have a brand AVO450 It have never been run but it has a tiny bit of shaft play Is this normal?
wetroads
Postby wetroads » Fri May 22, 2009 2:31 pm
j.l.c wrote:Steve,
I have a brand AVO450 which I am about to fit. It have never been run but it has quite a bit of shaft play! Is this normal?
Compared to other types of turbos the ball bearing turbos do have a bit of shaft play, as long as it's only a mm or so it's normal.
Steve.
scoobyrex
Blue MY06 WRX Driver
Postby scoobyrex » Fri May 22, 2009 3:22 pm
Hi Steve,
Just wondering what is the diference between the AVO 450 and AVO 450s :? Would the AVO 450 be an overkill for an MY07 with stock internals :?
Image Image
wetroads
Postby wetroads » Fri May 22, 2009 4:09 pm
scoobyrex wrote:Hi Steve,
They are a different core, I would go the 450s for your car, similar top end to the 450 but much better response.
Steve.
scoobyrex
Postby scoobyrex » Fri May 22, 2009 6:00 pm
:cool: Thanks Steve, shall stick to the 450s then :thumbs: Can't wait :roll:
Image Image
adz
Postby adz » Sat May 23, 2009 6:14 pm
Hey Steve have you got any dyno charts for a 2L with a avo320 (silicon intake, tbe etc)? Am interested in the spool characteristics of this turbo
Proud to be australian
MY99-00 ON GAS 196kw
Hasti
Postby Hasti » Sat May 23, 2009 7:19 pm
Hey Steve what about the 450L how diff is that to the others? I have a 06 sti I plan to fit one to as well as a few fuel mods.
Matt
92 RS Lib - No more!
06 STi - No more!
01 GT Foz - No more!
99 V5 STi coupe - Current.
olgus69
Postby olgus69 » Sun May 24, 2009 6:32 pm
Hi i just purchased a 400l, i have a 97 wrx with 3" tbe, cai, larger tmic, is my next step injectors and fuel pump, computer reflash? and wat sort of power can i expect from standard internals(100k on motor). thanx
wetroads
Postby wetroads » Mon May 25, 2009 8:35 am
adz wrote:Hey Steve have you got any dyno charts for a 2L with a avo320 (silicon intake, tbe etc)? Am interested in the spool characteristics of this turbo
There are a few on the dyno yes, however I'm only working from home these days and dont have the dyno files here yet. Best to email Lee on lee@avoturbo.com and ask for charts that way until I can get something sorted here.
We don't sell too many 320hp turbos these days as the 400s spools almost as well but has far superior top end and the VF34 is very close to the 320hp and can generally be bought for less.
Steve.
wetroads
Postby wetroads » Mon May 25, 2009 8:37 am
Hasti wrote:Hey Steve what about the 450L how diff is that to the others? I have a 06 sti I plan to fit one to as well as a few fuel mods.
Matt
HI Hasti,
The 450hp isn't my favorite turbo of the bunch, I would HIGHLY recommend you go for the 450s unless you have done every possible flow mod to help the 450hp out.
Steve.
wetroads
Postby wetroads » Mon May 25, 2009 8:38 am
olgus69 wrote:Hi i just purchased a 400l, i have a 97 wrx with 3" tbe, cai, larger tmic, is my next step injectors and fuel pump, computer reflash? and wat sort of power can i expect from standard internals(100k on motor). thanx
A stock MY97 engine I wouldn't push much past 200kw atw, maybe less depending on how the engine sounds, a 400s might have been a better choice, particularly if you're sticking to a tmic. On a good setup the 400L will easily make 260kw, sometimes more.
Steve.
adz
Postby adz » Mon May 25, 2009 8:21 pm
Hey steve thanks i spoke to Lee today and am looking at a 400s now. He showed me some charts of a 400s vs a vf34. For every one else the 400s hits peak boost later than a 34 (approx 300rpm) but makes more power down low (and right across the rev range) than a 34. The 34 has to run more boost to make less power (top end) than the 400s. It helps to see the dyno charts of each but it just confirms what people have been saying about the 400s. Only thing left to do now is to get AVO to lower the price and it would be the turbo to get lol
Hasti
Postby Hasti » Tue May 26, 2009 7:11 am
Hi Steve, thanks, i was concidering the 450s.
What are your thoughts I am stuck, its either the 450s or the TD06 20g.
Please give me your thoughts.
Matt
06 STi - No more!
wetroads
Postby wetroads » Tue May 26, 2009 8:03 am
Hasti wrote:Hi Steve, thanks, i was concidering the 450s.
Matt
Hi Matt,
The best thing to do in that situation is to try and get a drive in a well sorted car that runs the turbos you're interested in.
Steve.
Hasti
Postby Hasti » Tue May 26, 2009 9:03 am
Thanks Steve, Ive asked but no one seems to have a 450s fitted?
Anyhow thanks
Matt
06 STi - No more!
wetroads
Postby wetroads » Tue May 26, 2009 9:30 am
Hasti wrote:Thanks Steve, Ive asked but no one seems to have a 450s fitted?
Anyhow thanks
Matt
Give Lee or Justin a call on 9584-4499, they should be able to put you onto someone.
Steve.
Nitropro
Black MY06 Wagon Driver
Postby Nitropro » Thu Jun 18, 2009 1:20 pm
Hi Steve,
Quick question for you, as you suggested I wish to get an EBC with the 30kw package. I have read that you supply that as an option to any package. Which EBC do you offer and what would be the additional cost of supply and installation?
Nitropro
MY06 WRX Wagon - Team BlackWagon
Resonatorectomy, Railectomy
H&R Springs/RStruts, Yoki AD08's,
F&RSwayB, F&RStrutB, ALK, Diff Lock Support
CES TBE, TurboXS TMIC, HP-Flash
wetroads
Postby wetroads » Thu Jun 18, 2009 1:46 pm
Nitropro wrote:Hi Steve,
For the Subarus we usually use either an AVC-R or an EBoost2, fitting and setting up on the dyno usually runsa around $231. I would have to check current pricing for supply but it is likely you can buy then cheaper (ebay etc) than I can from the supplier.
Steve.
94GC8
Postby 94GC8 » Fri Jun 19, 2009 3:19 pm
Hi mate, i have a 94 rex maybe a sti not sure. This car has alot of work done strengthened internals, gearbox and high flowed stock turbo the vf22 i think. I am about to get some 660cc injectors, i was wondering when i decide to get a new turbo what horse power can i achieve and what turbo would you think be best been talking to all star garage in perth and they say 1.5 bar is on the safe side and i want a turbo that could easily handle those boost levels. Thanks for your help.
wetroads
Postby wetroads » Fri Jun 19, 2009 3:57 pm
94GC8 wrote:Hi mate, i have a 94 rex maybe a sti not sure. This car has alot of work done strengthened internals, gearbox and high flowed stock turbo the vf22 i think. I am about to get some 660cc injectors, i was wondering when i decide to get a new turbo what horse power can i achieve and what turbo would you think be best been talking to all star garage in perth and they say 1.5 bar is on the safe side and i want a turbo that could easily handle those boost levels. Thanks for your help.
Can you list all your mods? Cooler, etc...
Steve.
Return to “AVO”
