liquid LP Gas Conversion at AVO
AVO Ross
Club Supporter
Postby AVO Ross » Thu Feb 25, 2010 1:20 pm
Ross Wilson
AVO Turboworld
For your JDM Subaru Parts visit AVOJDM.com
AVO Ross
Club Supporter
Re: liquid LP Gas Conversion at AVO
Postby AVO Ross » Mon May 31, 2010 9:34 am
Save Some $$ with LPG
Ross Wilson
AVO Turboworld
dimi
Red GC8 Driver...
Red GC8 Driver...
Postby dimi » Wed Jun 02, 2010 12:38 am
Wow, how much does it cost for the conversion? i couldnt find a price...
Mica Red MY00 - 2006 Black Suzuki GSX-R 750
FOR SALE
"S1CK3M" Number Plates - VIC
lee
Club Supporter
Postby lee » Wed Jun 02, 2010 9:30 pm
What year is your WRX Dimi?
Lee Wilson
AVOTurboworld
www.avoturbo.com
57 Taunton Drive
Cheltenham
Vic. 3192
Ph : 03 9584 4499
ppshy1
Postby ppshy1 » Wed Jun 02, 2010 10:35 pm
Can a WRX actually run on LPG.
If so i might be keen when petrol prices got over 160c agains.
I know Subaru mantains boxers + LPG = disaster. But thans all manufacturers say that.
cracka
Postby cracka » Thu Jun 03, 2010 9:19 am
lee
Club Supporter
Postby lee » Thu Jun 03, 2010 11:20 pm
The JTG Liquid Kit was very surprising as to how well it did work and there was the added bonus of making more power and torque. The price of the kit is not cheap but if you plan on keeping the car for longer than 18 months then you will make the initial layout back then saving upto $1.00 per litre. I have a kit on my VE SSV Ute and it is great filling the vehicle up for $40.00 and getting 420 kilometres per tank.
Lee
AVO
Lee Wilson
AVOTurboworld
www.avoturbo.com
57 Taunton Drive
Cheltenham
Vic. 3192
Ph : 03 9584 4499
cracka
Postby cracka » Fri Jun 04, 2010 4:29 pm
Surprised i haven't heard more about rexies going to gas since "ads" got his car converted as it sounds like
great idea.
What more info can you give us lee and have you got any other examples of converting a Subaru to gas.
Maybe some graphs etc , a ball park figure $$ ,is there still a gov' rebate going ? etc etc
lee
Club Supporter
Postby lee » Tue Jun 08, 2010 11:20 am
The liquid gas kit would be $4750.00, supplied and fitted. There is currently a $1750.00 gas rebate still available from the government.
The only issue may be that if there is major on the vehicle modifications then a ECU retune would be required and that would be extra.
Lee Wilson
AVOTurboworld
www.avoturbo.com
57 Taunton Drive
Cheltenham
Vic. 3192
Ph : 03 9584 4499
cracka
Postby cracka » Tue Jun 08, 2010 3:54 pm
i thought a retune would be automatically be required.
Is it dedicated LPG or will my 01sti ecu need to run dual maps (if it can)
lee
Club Supporter
Postby lee » Wed Jun 09, 2010 10:56 pm
if the vehicle is standard or virtually standard then it will not need to be tuned as the gas injectors mimic the factory fuel injectors. For modified situations, you will probably need a Link ECU with a dual map setup.
Lee Wilson
AVOTurboworld
www.avoturbo.com
57 Taunton Drive
Cheltenham
Vic. 3192
Ph : 03 9584 4499
AVO Ross
Club Supporter
Postby AVO Ross » Wed Aug 04, 2010 11:42 am
AVO Turboworld is a certified LPG installation facility and tuner. We have had tremendous success with all our installations and conversions to many Ford, Holden and Subaru models.
Why AVO uses Liquid Gas Injection System
When LPG is used to fuel internal combustion engines, it is often referred to as autogas or auto propane. In some countries, it has been used since the 1940s as a petrol alternative for spark ignition engines. Its advantage is that it is non-toxic, non-corrosive and free of tetra-ethyl lead or any additives, and it burns more cleanly than petrol. And if you are interested in more performance from your vehicle, it's high octane rating (108 RON) is especially attractive. The advantage of the AVO system is the option of our dual-fuel tuning, which optimizes performance. Our professional tuners will create the optimal map specifically tuned for your car on our high-tech in-house dyno.
The JTG Liquid Injection System
The JTG Liquid injection System is a premium product that delivers excellent drivability and performance above vapour injection and traditional venture systems. The reason why the JTG Liquid injection system delivers better drivability and performance is due to the system injecting liquid LPG into the inlet manifold port next to the petrol injector. By doing this the liquid LPG vapourises in the inlet manifold and lowers the inlet air temperature. This provides a more dense air/fuel mixture which fills the combustion chamber more completely (increasing the engines volumetric efficiency).
The system advantages are as follows:
More power than running on petrol
Higher mid range torque than petrol
Approximately 10% improvement on fuel consumption when compared to vapour injection systems
Less intrusive fitment to vehicle (no water hose connections)
Lower combustion temperatures than other gas systems (protecting engine durability)
Large benefits for turbo or supercharged applications
Injects LPG vapour next to petrol injector – no backfire possible unlike venturi system
Exhaust gas emission testing has proven that LPG powered vehicles emit up to 10% lower CO2 (Green house gas) emissions.
Exhaust Gas Emission Milestones
1. Euro 2 compliant kits (vehicles from 2002 to 2005)
2. Euro 3 compliant kits (vehicles from 2005 to 2010)
3. Euro 4 compliant kits (vehicles from 2006 to 2010)
4. First company to certify Liquid Injection LPG kits to emission requirements of AS/NZ-1425
Ross Wilson
AVO Turboworld
LPG
Postby LPG » Sat Aug 28, 2010 11:34 am
Gday,
Has anyone converted to Liquid LPG and had any problems? I am having trouble converting with stalling or really rough conversion.
lee
Club Supporter
Postby lee » Mon Aug 30, 2010 10:09 pm
Hi LPG,
We have just recently completed a liquid injection installation on a Forester 06 2.5L Turbo Model. The installation worked well and made over 10% increase in power.
Let me know if you can help you with anything else.
Regards,
Lee
AVO
Lee Wilson
AVOTurboworld
www.avoturbo.com
57 Taunton Drive
Cheltenham
Vic. 3192
Ph : 03 9584 4499
LPG
Postby LPG » Mon Aug 30, 2010 10:53 pm
Gday
Thanks for that. I have had my installer and Australian Gas Warehouse look at it with no success so I was wondering if there are any comon faults with the ICOM JTG system. I have spoken to one supplier that has stopped installing them due to faults that couldnt be fixed but I havnt been able to hear from anyone who actually had the problems which is why I posted this message. My problem is basically stalling or very rough conversion when hot.
AVO Ross
Club Supporter
Postby AVO Ross » Thu Oct 28, 2010 12:22 pm
Forester LP Gas Install before and after
Ross Wilson
AVO Turboworld
AlexNorinh
White Wheeled Blue Bugeye WRX Driver
Postby AlexNorinh » Thu Oct 28, 2010 4:02 pm
that's a pretty rich run on gasoline (~10.3 afr)
lee
Club Supporter
Postby lee » Thu Oct 28, 2010 10:48 pm
Hi Alex,
If you are talking about the blue line of the gas setup, about .84 to .88 lambda. It is conservative but not over the top rich. This is the standard kit without tuning. With tuning it could be trimmed more.
Lee
AVO
Lee Wilson
AVOTurboworld
www.avoturbo.com
57 Taunton Drive
Cheltenham
Vic. 3192
Ph : 03 9584 4499
MY2006
Postby MY2006 » Wed Dec 08, 2010 7:38 pm
Hi Lee
what has happened to my quote? Been waiting since September?
Some questions:
1) does LPG has any negative effects on the valves, as some say it is a drier fuel and does not lubricate as well as petrol?
2) how much added weight is the setup.
3) with the added weight and extra power, what is the effect on the 0-100km/h figure
4) how is the balance of the car affected, especialy on track days?
Regards
Albert
WRX MY97
www.ahcs.net.au
Supplier of Subaru powered equipment, Penrite Oil
Subaru Genuine Parts at competitive prices
Return to “AVO”
