PFI top feed fuel rail kit
Moderators: Advertising Manager, tu
Postby tu » Sat Jul 21, 2007 4:52 pm
Here's a very nice bit of gear for those looking to do a parallel fuel rail conversion or looking for better fuel supply on their WRX or STi. Made by Powerflow these fuel rails come as a complete upgrade with a matched set of topfeed Denso injectors (any size from 380-1600cc) and are designed as a straight bolt on for all rexes from 94 to current. As an additional bonus for early model rex owners this allows you to convert from sidefeed injectors to top feed. Priced at $980 these are an excellent upgrade option. Also recommended is an aftermarket fuel regulator like the Turbosmart FPR1200 range.
Check them out in store here
Re: PFI top feed fuel rail kit
Postby Plattsy » Fri Dec 19, 2014 3:00 pm
hi mr tuspeed, i emailed you yesterday.
i know youve changed manufacturer now, but can you explain how yours work around the drivers side header tank/lack of space conumdrum.
do i need to chop sheet up?
Return to “Tuspeed”
