T70 torx
Moderators: Advertising Manager, tu
EREXON
T70 torx
Postby EREXON » Mon Mar 18, 2013 8:13 pm
Hi Adam,
Do you have the T70 torx bit in stock.
Ordered one from the states and it got lost after 1month wait.
Dieing to change the gearbox oil and can't find a torx bit.
I read that you once had them in stock? Any luck? These bolts won't budge even my diff bolt is soooo tight.... This will be fun :wall:
MY07 WRX Tuned by STi #136
TBE - STi TMIC splitter - VF43 - 3 Port - Walbro 255L
Chasers tune @ 190.1Kwatw - RIP
MY12 WRX Premium
LEDs, FRONT LIP
INVIDIA TBE, AEM CAI, PW TMIC, TP tuned
BC BR's
blackrex
Black BMW M6 Driver
Black BMW M6 Driver
Re: T70 torx
Postby blackrex » Mon Mar 18, 2013 9:54 pm
I am not sure why people order these tools from o/s when you can buy them from places like Total Tools, Bearing Wholesalers and other industrial suppliers, even some Bunnings and Masters have them.
"The problem with socialism is that you eventually run out of other peoples money." Margaret Thatcher.
TINSTAAFL
rickzta
Club Supporter
Re: T70 torx
Postby rickzta » Mon Mar 18, 2013 10:29 pm
Adam has them on the shelf...
2 Door Widebody in the build process...
tu
TUSPEED
TUSPEED
Re: T70 torx
Postby tu » Tue Mar 19, 2013 10:07 am
Got lots in stock - how many do you need? :)
http://www.tuspeed.com
EREXON
Re: T70 torx
Postby EREXON » Tue Mar 19, 2013 11:05 am
blackrex wrote:I am not sure why people order these tools from o/s when you can buy them from places like Total Tools, Bearing Wholesalers and other industrial suppliers, even some Bunnings and Masters have them.
The reason I ordered from O/S was because I tried bunnings, masters, autobarn, super cheap, total tools, repco.
No one had anything larger than T50. I did find a T60 which some ppl say works but made things worse.
So then I ordered from O/S and they failed to deliver twice.
If I knew Adam had them earlier it would have saved me a lot of trouble. I don't think I'm the only one who has struggled to find them.
MY12 WRX Premium
LEDs, FRONT LIP
BC BR's
EREXON
Re: T70 torx
Postby EREXON » Tue Mar 19, 2013 11:08 am
tu wrote:Got lots in stock - how many do you need? :)
Will drop past after work today and pick one up!
Might need more than one the way these bolts care tightened. I can't understand why they are so bl00dy tight :wall:
Even my rear diff is super tight. I put a jack on the breaker bar and the whole car raised without the bolt coming loose!
MY12 WRX Premium
LEDs, FRONT LIP
BC BR's
deejw
Re: T70 torx
Postby deejw » Tue Mar 19, 2013 12:11 pm
trick is to tighten until the seal cracks then untighten
New Foz Build http://ozfoz.com/forum/viewtopic.php?f=12&t=43042
EREXON
Re: T70 torx
Postby EREXON » Tue Mar 19, 2013 2:06 pm
I'll add that to the list of things to try. Thanks!
I'm also having the guys at work make a little fixture that I can attach the socket to and hit with a hammer. Apparently the short distance of a solid plate and a impact can crack them.
I'll try just about anything at the moment :hairpull:
MY12 WRX Premium
LEDs, FRONT LIP
BC BR's
EREXON
Re: T70 torx
Postby EREXON » Wed Mar 20, 2013 8:37 am
So seems like the right tool did the job. Hit the ratchet with a hammer a few times in both directions and then breaker bar cracked it right off!
Thanks Adam for hooking me up with torx bit :cheer:
MY12 WRX Premium
LEDs, FRONT LIP
BC BR's
treeman
Re: T70 torx
Postby treeman » Wed Mar 20, 2013 8:56 am
Had exactly the same problem went to all the above shops, total tools had a t60 they said it might work, so I tried it and made the bolt worse. Then I got a t70 from tuspeed, had no chance with a normal ratchet, even a extension bar did nothing.
On my last desperate attempt I used a 2m long hollow pole from a outdoor umbrella, its amazing how much more torque I was able to get through such a long pipe. The huge crack the bolt made when it finally came off I thought I snapped it.
EREXON
Re: T70 torx
Postby EREXON » Fri Apr 12, 2013 10:14 pm
Hi Adam,
Do you have a 13mm square for the rear diff bolt????
I am having the same issue where the 1/2" drive is chewing into the bolt because there is slight movement. The square is perfect 13mm.
Can't undo my diff bolt nervous
MY12 WRX Premium
LEDs, FRONT LIP
BC BR's
Return to “Tuspeed”
