Current/Previous owners - Liberty 4Gen MY04 GT
jay
Postby jay » Fri May 18, 2012 10:34 am
I'm used-car shopping and an this is an option. Any current/previous owners who can tell me of any problems/faults experienced with this model http://redbook.com.au/cars/research/used/details?R=98217&Silo=Spec&Vertical=Car&Ridx=33&eapi=2
Respect the Rex :)
qship
Re: Current/Previous owners - Liberty 4Gen MY04 GT
Postby qship » Fri May 18, 2012 11:56 am
2004 were auto only - Manual available from 2005
Needs 98 ulp, not 95 as in text
Premium pack (leather and sunroof) was optional - Std in 2005
Regular faults include O2 sensors and maf failures, On some the variable valve timing can fail due to blockage of oil to the system (not often but it can happen)
Check all the usual places for mods - look for burred nuts, a too clean exhaust, holes drilled under dash etc. As in all cars, the shockers can go soggy with age and the front rubber bushes should be watched as they can sometimes split. I'm sure others can contribute more.
If well cared for they are quite reliable. Major service at 112500k includes all fluids and timing belt and is big$$
Good luck
You can lead a fool to knowledge but you cannot make him think!
bass_straitener
Postby bass_straitener » Fri May 18, 2012 12:58 pm
Your best bet is to jump on here and ask the same question or do a search.
http://forum.liberty.asn.au/index.php
"If A is a success in life, then A equals x plus y plus z. Work is x; y is play; and z is keeping your mouth shut."
Return to “Liberty Related Discussion”
