Update - 313awkw's + 565Nm wheel torque + lots PICS
keverns
Re: Update - 313awkw's + 565Nm wheel torque + lots PICS
Postby keverns » Thu Oct 06, 2011 4:49 pm
was following your photo bucket few month ago and damn...what a good turnout. awesome house....too much money...i want :ras2:
how many maids do you have?
robos4
Postby robos4 » Mon Nov 21, 2011 6:07 pm
need some help..
It seems my gear box is struggling :(
Almost 3 out of 5 shifts under WOT into 3rd results in a lock out.. Just wont go in.
If I drop boost - no probs.
Normal driving - feels perfect.
Just going 2nd to 3rd under full attack does not go in most times. I just changed the gear box oil again to Motul plus some additive which is supposed to help but same problem.
This started happening about 5 months ago and slowly getting worse..
Suggestions?
Rob
07 Black STI - Singapore
Dom 3 turbo with the works
muzza
Black MY06 STI
Black MY06 STI
Postby muzza » Mon Nov 21, 2011 6:20 pm
Do you have hd mounts and harder shift bushes?
When my shift linkage was worn it would hang up on the 2-3rd shift.
robos4
Postby robos4 » Mon Nov 21, 2011 6:30 pm
hmm,
I have done gear box mount plus engine mounts (used the upgraded STI brand - can't remember name). Broke the last set of them (probably from launching too much). replaced with same brand.
I have a short shifter in too.
Ohh and twin plate clutch (which my mechanic thinks might be causing some of the problem)
Is there anythign else I can upgrade/change to see if it will fix this problem?
thanks!!
Sime
Postby Sime » Tue Nov 22, 2011 8:40 am
robos4 wrote:hmm,
uhhhhhh.......your gearbox?!
No seriously, perhaps it's time to start thinking about a PPG 5 speed straight cut box? They can handle oodles of power and make an awesome sound too.
Paintwerks.com.au
Accident repairs -- Restorations -- Spray painting
PPG Authorised Refinisher
Seetal LowBake Spraybooth for hire
9a Ebden Street, Moorabbin VIC 3189
(03) 9555.4555
M-F 9.00am-6.00pm
PAT555
MY99 WRX Driver
Postby PAT555 » Tue Nov 22, 2011 11:50 am
Perhaps time to think about just buying a standard GT2 that works and goes right at full attack from factory..
No offence but your car is one headf@ck after another.
Sharpie
Subie Guru
Postby Sharpie » Tue Nov 22, 2011 12:42 pm
syncro/hub and sleeve is worn seen it before, just buy another box secondhand. Something close ratio jdm :cool:
X-Sti Melbourne Foreman and backyard boy.
just p.m. me.
bazzasti
Postby bazzasti » Tue Nov 22, 2011 12:53 pm
Sime wrote:
robos4 wrote:hmm,
They're only a touch stronger and don't have oil pump and need to be rebuilt for around 3k every 20,000 kms. Dccd is the old open version.....
robos4
Postby robos4 » Tue Nov 22, 2011 3:48 pm
lol
Thanks for the advice..
I have been told a mech can buy stronger syncro's and at the same time re set my gear ratios to what ever I like.
This can be done for under 2-3k Sgd..
Any reaosn why I should not consider this?
I'm sure it will only last a year or so, but thats fine as far as what I'm prepared to pay.
bazzasti
Postby bazzasti » Wed Nov 23, 2011 10:58 am
robos4 wrote:lol
Never heard of "stronger" syncros and don't know if they exist. He may have meant better syncros with fancier triple cones / whatever etc.
I'd just replace whatever you wear out - 6MT's are awesome boxes.
T-Rex
MY04 WRX Driver
MY04 WRX Driver
Postby T-Rex » Wed Nov 23, 2011 6:20 pm
Stronger synchro's exist with some other makes, ie Nissan. But you don't tend to see them outside of Japan for some reason. I'm not sure if any better ones have been made for Subaru's.
Full Race wrote:A smaller a/r has less efficiency at low flow and higher efficiency at high flow. A larger a/r has more efficiency at low flow and less efficiency at high flow
robos4
Postby robos4 » Thu Nov 24, 2011 5:53 pm
spoke to that mechanic again and he said they will send off the gears and have them strengthed in the US. They say about 20% stronger.
However for my problem it's more about worn syncros and maybe some other worn parts.
We will open it up take a look and replace syncros and what ever else needs doing. :)
Ordering my new GT3586 turbo tonight punk
XXXREX
Postby XXXREX » Thu Nov 24, 2011 8:40 pm
try out a t51r for fun nerd
Regards
Your Mum
T-Rex
MY04 WRX Driver
MY04 WRX Driver
Postby T-Rex » Thu Nov 24, 2011 10:34 pm
A guy here made 450kw with 31psi using a twist mount precision billet turbo. Mind you he has customised a lot more than you but you're missing out on a lot by not going twist, i thought you were considering it?
robos4
Postby robos4 » Fri Nov 25, 2011 12:32 pm
Sorry I may be getting confused.
Whats twist mount? (Is that the same as rotated and or offset turbo) lol not good with car talk these days haha
This is what I'm getting:
I currently have the largest size GT35 in stock location, the only way up from here is to rotate it. I will run a 4" intake, and TRY to run as bigger dump pipe as possible (only up to the exhaust cut out) and then run usualy smaller exhaust to keep it quiet on street.
This turbo is the FP HTA GT3586 with Tial V-band A/R 0.82. I'm expecting a small gain in spool increase (300-400rpm) and 700-1000rpm gain in peak power.
Should be in and done before end of the year if all goes well. Of course I will keep everyone up to date on the progress and results :)
Then I need new tyres and gear box to be done haha
T-Rex
MY04 WRX Driver
MY04 WRX Driver
Postby T-Rex » Fri Nov 25, 2011 5:59 pm
Yes twist mount is the same as rotated or offset. Somewhere around 400kw would be achievable with that turbo I presume?
sonny0186
Postby sonny0186 » Fri Nov 25, 2011 10:18 pm
That's a huge mother f**ker, that can swallow possums
CURRENT:
EVO ~ 225awkw, 392nm tq
WRX ~ 200awkw
VF24, PW TMIC & CAI, STi blue injectors, GS 3 port solenoid, Walbro 255lph fuel pump, Samco hoses, Selby's rear sway bar, Project Mu NS pads.
robos4
Postby robos4 » Sat Nov 26, 2011 12:10 pm
Yeah, I chose this one based on the results many of the guys achieved on this forum and evo forums too.
That picture is actually not the GT3586, it's the Gt3582 :)
Think I'll tune it for 1.9bar and see what it gets, then go from there..
The question I have - has anyone successfully installed a 4" dump pipe as it looks very tight with the steering and other RHD stuff in the way...
robos4
Postby robos4 » Mon Nov 28, 2011 5:43 pm
So in the end I went with a set of AD08's :)
They weigh less than the RE-11's, they are A- Symetrical (able to rotate left to right to aid excess camber) plus were $150 cheaper per tyre (and in stock too lol)
245x35x19 punk
Had to remove the rear spacers as it looks REAL tight back there.. will find out soon if it still rubs. From now is reduced to 7mm spacer and it too looks VERY tight.
Now just need to wait for that turbo..
DChristie
Postby DChristie » Mon Nov 28, 2011 8:26 pm
Are you sure that turbo is not from a mining truck or maybe the now defunct space shuttle...surely it won't fit in the engine bay. lol.
Nice car man, if i'm ever in Sing again you gotta take me for a spin!
02 STi
Return to “General WRX and Club Discussion”
