Dom 3 XTR on 2.1L with 272 kelfords
jayjay82
Postby jayjay82 » Tue Aug 29, 2017 7:33 pm
I have a version 6 sti with the following
- scd ver 8 ej207 block
- nitto forged rods
- weisco forged pistons
- ARP 625 head studs
- big port heads with porting
- kelford 272 non avcs cams
- process west tmic
- dom 1.5 xtr
- 1000CC DW injectors
- long ratio 6 speed
Obviously there is far more but these are the important things
Car made 263awkw on bp98 at 1.6bar
I only use the car for drag racing and am considering ditching the dom 1.5 xtr for a dom 3 xtr.
I cant be bothered going twist mount because i want the engine bay to remain factory looking.
The car ran 11.6 @ 123mph
Has anyone had a dom 3 xtr on a 2.1l with cams? I know it will be laggy but in drag racing it wont matter.
Im hoping for 300awkw on bp98 or very low 11s.
Should the dom 3 get me there?
KuRT12
Re: Dom 3 XTR on 2.1L with 272 kelfords
Postby KuRT12 » Wed Aug 30, 2017 12:39 pm
Hey mate,
the guys at got it rex had a car with similar setup on a Dom 3 making 360kW (e85)
https://www.facebook.com/gotitrex/posts ... 6833966973
jayjay82
Postby jayjay82 » Wed Aug 30, 2017 4:31 pm
Yeah i saw that. There is absolutely no e85 where i live so will have to remain bp98.
Just hoping it will make 300kw on 98 with a TMIC
roh008
Postby roh008 » Sun Oct 01, 2017 6:05 pm
jayjay82 wrote:I have a version 6 sti with the following
That's already as fast as a 2017 stock Nissan GTR :shock:
What's the 0-100 in your current setup, also what would it be like as a daily?
MY11 STI Spec R WR Blue
rexmang
Postby rexmang » Fri Oct 06, 2017 9:27 am
A dom 3 will get you there but you will need a fmic or even better a water to air setup in the tmic position. 98 needs good cooling to see 300 and a tmic will struggle. Running a water to air on mine, when set up correctly there is nothing better.
99 V5 STI Team coupe| built 2.5L|Dom 3 XTR 8cm@26psi|Water to air goodness| 07 STI 6MT dccd Short box | Brembos|
Return to “General WRX and Club Discussion”
