GT Boostgauge VBG1 - Vent Boost Gauge 1st Gen
gammachan
Postby gammachan » Sat Jul 02, 2016 10:46 pm
Brand new never installed opened to inspect. Sad to let it go but not enough time to install this and it's just sitting around.
For WRX/STI 08-14
Installs in right center vent (NON-US Domestic Market)
Boost and Vacuum gauge - 48 PSI max Dual OLED screens provide Digital information one of a kind boost profile plots
5X Peak boost memory
Dimming capability for night time viewing when illumination wire is utilized or auto Dimming feature using built in ambient light detector
A single auxiliary sensor input can be utilized (sold separately)
Compatible with LC-1 AFR analog output
AFR via PLX serial input
Oil pressure (approved sensors only)
Volt meter built in
High and low alarms configurable
Led bar graph:
Pressure:
Full mode 0 - 24 PSI (1X mode) 0 - 48 PSI (2X mode)
Pivot mode 0 - 16 PSI (1X mode) 0 - 32 PSI (2X mode)
Vacuum display options:
Full mode 0 - 24 in. Hg (2 in. Hg per LED)
Pivot mode 0-25 in Hg (3 in. Hg per LED)
User manual link
http://www.gtboostgauge.com/VBG1%20-%20 ... 0V1.08.pdf
Will also include tubing and fittings
$250
A nice saving from the USD.
Postage on top
Spare vent also available so you don't have to take yours apart $20
gammachan
Re: GT Boostgauge VBG1 - Vent Boost Gauge 1st Gen
Postby gammachan » Sun Jul 03, 2016 9:28 pm
SOLD
Return to “Moved and Archived CLASSIFIED Ads”
