Door Speaker Spacers Templates
Postby MrEs » Thu Aug 16, 2007 6:15 pm
deafwish
Silver MY06 STi Driver
Postby deafwish » Thu Aug 16, 2007 10:32 pm
Nice job, Es! :thumbs:
mattrix
spacers
Postby mattrix » Fri Jan 04, 2008 10:57 pm
btw the rear is just a copy of the fronts......
doesn't match up!
cheers,
Great front template!
Mattrix
angel-is-back
Re: Door Speaker Spacers Templates
Postby angel-is-back » Fri Jul 04, 2008 9:13 am
the only thing i will ad to this is that each speakers installation diameter is different, so when using this template first use the template that came with the speakrs to cut out the speaker opening hole, then you the template above to finish off.
scatteredmac
Postby scatteredmac » Thu Jan 15, 2009 8:42 pm
I'm new to this and unsure where I post my query.
I am upgrading sound system and want to make sure the install goes smoothly. Just put a brand new Pioneer DEHP7050BT CD TUNER MP3 TUNER IPOD USB BLUETOOTH and want to upgrade door speakers, put in amp and sub. I'm right with the amp and subs but want to put in speakers that will basically slot straight in with out the need for spacers etc. If possible. I can't seem to find the dimensions of the exisisting speakers and don't really want to take door trims off twice. So far I have one person say to me that 6" or 16cm diameter and 42mm (depth restriction without spacers). Is this correct?
And just to clarify the system I am thinking of putting in:
PIONEER
GM6300F 4 CHANNEL AMP $264
TSA1672S 3 WAY SPEAKERS (2 pair) $152
TSSW1241D Subwoofer $224
TrueBlue759
Postby TrueBlue759 » Fri Jan 30, 2009 11:23 am
Just want to make sure this is for all rexy's. Not just a certain year or model.
pnkbits
Postby pnkbits » Thu Jul 09, 2009 1:06 am
TrueBlue759 wrote:Just want to make sure this is for all rexy's. Not just a certain year or model.
x2
deafwish
Postby deafwish » Wed Sep 23, 2009 5:38 pm
I'm getting a mate (professional) to make up the front speaker rings - if anyones interested?
They will be $50 a pair and will be resin coated & painted black to stop moisture absorbtion.
They will suit 6" speakers and will have an internal mounting diameter of 127mm.
Kindly let me know ASAP as he will be making them over the next few days.
Daz.
claor
Postby claor » Wed Sep 23, 2009 5:48 pm
Most speakers people buy are 6.5" though. youd be bettter off getting jukebox ? to make them for 6.5's and one set smaller for your speakers (if you have 6 inch)
Jason
deafwish
Postby deafwish » Wed Sep 23, 2009 5:54 pm
Jukebox can make either, but 6" will be easier as that's what my template will be. :wink:
deafwish
Postby deafwish » Fri Jan 08, 2010 3:42 pm
Anyone have a template for the 4" rears?
siu_loong_bao
Postby siu_loong_bao » Thu Dec 29, 2011 6:55 pm
For MY11 Non-Prem owners....the front and rear door speakers are 6.5"....The rubbish set of SONYs that I bought (and now uninstalled) fit directly onto the factory mounts/spacers on all the doors...that is, a direct swap.
Michaelpiranha
Postby Michaelpiranha » Wed Jan 28, 2015 7:05 am
when i go to download them says there is nothing there ??????
