CHANGING DASH LIGHT COLOURS
rexevos
Postby rexevos » Sun May 17, 2009 7:52 pm
hi guys..
just wondering has anyone attempted to change the dash light colour and the cluster colour?
i want to make my whole dash red instead of the green on my 05 wrx...
i was considering to go out and buy a sti cluster but if i can get the lgihts to change colour to either WHITE or RED it might be better and cheaper..
any help :D
White 05 WRX, Sti kit Carbon fibre number plate suround, 18x9.5 ROTA GRID in white, Jet Black roof and sitting FLUSH !
rego: IPHATI
Domino
Re: CHANGING DASH LIGHT COLOURS
Postby Domino » Sun May 17, 2009 8:35 pm
It's pretty simple, you can either get silicon sleaves to fit over the T10 bulbs or get leds, in a few different colours. I saw red, green, blue, yellow and orange silicon sleaves today at Auto1. I bought the Narva Arctic Blue bulbs to see how they'll go, dont really like the GC8 green.
Just take your time taking out your speedometer, you should only need a phillips head screwdriver to get the job done.
rexevos
Postby rexevos » Sun May 17, 2009 9:19 pm
to change all the bulbs or put the sleeves on behind the dash where the climate controll stuff is.....is everything just click and screw off?
and i heard behind the speedometer/cluster their is a green plastic piece so it comes out green and if u take it off it comes out white?
but im not 100% on that..
ill spend time on it when i get the car back form the shop
rego: IPHATI
Domino
Postby Domino » Sun May 17, 2009 9:37 pm
The speedo is easy, but the climate control stuff can be a little tricky. The speedo will use T10 wedge bulbs but Im not 100% on the bulbs for the climate control.
Jadaz
the non-turbo fraudster
Postby Jadaz » Mon May 18, 2009 4:54 pm
i pulled my dash out 2 change the globes the other week. They are T5 in the dash, and the climate control are all LED. So i didnt bother as the plastics are green and no matter wat u do it will never be the exact colour...
i have a MY05.
if u manage 2 do it,let me know wat u did coz i want red as well.
Domino
Postby Domino » Mon May 18, 2009 6:01 pm
I put two multi-angle leds into the fuel and temp gauges, then the Narva arctic blue bulbs into the Klms/hr dial this afternoon. After taking forever to install a new head unit :hairpull:
The leds worked alot better than the Narva T10 bulbs.
mren2005
Postby mren2005 » Mon May 18, 2009 8:33 pm
awesome.. isn't there a DIY for this somewhere?
Murray
Jadaz
Postby Jadaz » Mon May 18, 2009 8:54 pm
Domino wrote:I put two multi-angle leds into the fuel and temp gauges, then the Narva arctic blue bulbs into the Klms/hr dial this afternoon. After taking forever to install a new head unit :hairpull:
Was urs the green dash???????????
Domino
Postby Domino » Mon May 18, 2009 9:38 pm
Yeah mine was green.
rexevos
Postby rexevos » Tue May 19, 2009 12:20 pm
ahh nice nice..
mine is a MY05 aswell
if i work it out 1 day ill let use know..
but i dont have the car back yet so it might be a while :D
rego: IPHATI
DeeJay
Postby DeeJay » Wed May 27, 2009 5:01 pm
hey Jadaz are the LEDs patchy? I did an LED conversion in my last car and i found there were darker and lighter spots, making the colour look patchy.
Jadaz
Postby Jadaz » Wed May 27, 2009 5:05 pm
nah they wernt.. i put red ones in, but it was just to dark wit the green dash, so took them out. Tried white aswell but same thing, TOO DARK.
get the wide beam (or flat top LED's)
DeeJay
Postby DeeJay » Wed May 27, 2009 5:26 pm
where is the best place to buy them? Jaycar?
have you got a photo of the whole dash with blue LED?
dimi
Red GC8 Driver...
Red GC8 Driver...
Postby dimi » Wed May 27, 2009 5:44 pm
Jaycar DOES stock them, as a mate of mine did the same thing to his R32 Skyline and looked good :)
Mica Red MY00 - 2006 Black Suzuki GSX-R 750
FOR SALE
"S1CK3M" Number Plates - VIC
Jadaz
Postby Jadaz » Wed May 27, 2009 6:17 pm
yer, u can go JayCar or Autobarn..
DeeJay
Postby DeeJay » Wed May 27, 2009 7:00 pm
I'm guessing the stock blubs are normal blubs and not LEDs, so I'm going to need to use a resisitor as well.
Jadaz
Postby Jadaz » Wed May 27, 2009 7:24 pm
the ones i got from autobarn came wit the resistor built into the T5 wedge...
5x LED's for $10 or so.
DeeJay
Postby DeeJay » Wed May 27, 2009 9:24 pm
I might have to give it ago.
It would be much easier with the pre-made T5 wedges!
On my VT i had to solder each LED and resistor!
Jadaz
Postby Jadaz » Wed May 27, 2009 9:28 pm
good luck. just remember they goa certain way, so if they dont come on first go. try again.
ROGRSS
Postby ROGRSS » Wed May 27, 2009 11:20 pm
Ive have just tried all this... with my 03 WRX. The blue t5 wide angled leds are the brightest but the needles are not very visable. Red comes up better but not as bright. Ive tried sleeves, leds and painted bulbs. In the end ive gone back to the green speedo etc with red for the ac and heater, and cigerette lighter and ignition. Im happy with that combo. i'll try put some pics up if you guys want ???
Pauly
When in Doubt..... Flat Out !!!!!
