98 Subaru Impreza WRX Keypad not working
wiam_t
Postby wiam_t » Sun May 08, 2016 3:09 pm
Ok so heres the deal my 98 wrx has the key pad imboliser from Subaru installed, the key pad works you can enter the 4 digit code but after you enter it the check engine light doesn't come on and i cant start the car. i have no idea whats stopping me from starting it Please help sad i cant drive the car. :( :(
2DIE
Re: 98 Subaru Impreza WRX Keypad not working
Postby 2DIE » Sun May 08, 2016 3:15 pm
There is 2 codes on my Brant alarm, one you only use after the alarm has gone off. Look up how to reset the Brant alarm, from memory it's something like remove the negative terminal and hold 0 on the pad.
Sent from my SM-N9005 using Tapatalk
2DIE
Postby 2DIE » Sun May 08, 2016 3:22 pm
Found how to do it properly.
Postby Yeldz » Sun May 08, 2016 3:42 pm
Check that you don't have low volts
