Car wont start after broken into.....
johnblaze3000
Postby johnblaze3000 » Sun May 15, 2016 8:32 pm
Hey guys,
A couple nights ago my MY99 GC8 WRX got broken into..
Pretty much got to the car doors were open locks were screwed ignition barrel was ripped out and now the car won't start..
Tried checking sparkplugs for spark - Clear
Tried checking all fuel lines/filter/pump/injectors - All clear and have pressure/pump is priming (used starter fluid and it worked as well)
The engine is cranking but not starting..
Thanks guys, any help would be appreciated..
Re: Car wont start after broken into.....
Postby mv75 » Sat May 28, 2016 4:26 am
Sorry I havn't, or anyone hasn't read this yet, but if you havn't sorted it, it may have had the transponder receiver damaged. Also check the under dash fuse box for the ignition fuse.
