Hey guys, so my gc8 is doing something very strange... i put the key in and turn it to start and it does nothing... like its dead, there is plently of power in the battery, dash lights ups, fuel pump primes, it just doesnt crank... and then sometimes if i hold the key in the start position for a few seconds it will crank and start as normal... or i take the key out and try a few times it starts....
i thought maybe it was the alarm... had it checked, all is good... ive been told it may be the starter relay?... any ideas?..... and if so where is the starter relay so i can change it.
any ideas would be great, thanks guys
George
Strange Starting Issue GC8 WRX
- [WRXTC]
- Impreza 22B Driver
(99 WRX)
(04 WRX STi)
(06 Liberty GT Spec B)
WRX STi
Tein Coilovers
Blouch TD05(24psi)
3" TBE
ID 1000cc Injecs
Walbro Fuel Pump
PSR Intake
PSR Headers
HD Clutch
HP-F Tune + E85 + Launch Control
(04 WRX STi)
WRX STi
Tein Coilovers
Blouch TD05(24psi)
3" TBE
ID 1000cc Injecs
Walbro Fuel Pump
PSR Intake
PSR Headers
HD Clutch
- Lupin
- S204 Driver
- Contact:
Re: Strange Starting Issue GC8 WRX
Didn't you just swap the ECU in this car.
- SHIZNT
- Impreza WRX Driver
I've had a similar problem but mine was dirty battery terminals not making contact properly.
starter motor? Bash it before putting the key in and see what happens
if your game you can unbolt the starter motor and have someone crank it while you watch and see if it turns.
New Foz Build http://ozfoz.com/forum/viewtopic.php?f=12&t=43042
- SHIZNT
Good point, I recently had a look at one of the misses friends cars. Car intermittently wouldn't start and had left her and her 2yr daughter stranded a few times.
Initially I thought it was her battery terminals are they were really loose, but after I nipped them up I noticed it wasn't making any clicking noise like not enough charge. Jacked the car up and got under.... surprise surprise loose wires on the starter motor.
- [WRXTC]
Lupin wrote:Didn't you just swap the ECU in this car.
yeah... but whats that got to do with not starting sometimes? lol
(99 WRX)
(04 WRX STi)
WRX STi
Tein Coilovers
Blouch TD05(24psi)
3" TBE
ID 1000cc Injecs
Walbro Fuel Pump
PSR Intake
PSR Headers
HD Clutch
(04 WRX STi)
WRX STi
Tein Coilovers
Blouch TD05(24psi)
3" TBE
ID 1000cc Injecs
Walbro Fuel Pump
PSR Intake
PSR Headers
HD Clutch
- [WRXTC]
problem solved guys, i pulled the starter motor out on the weekend, fitted one i sourced from brett at Sbaru parts, problem solved
.. must have been the starter solenoid or starter motor it self... but all is goood now shes running like a dream!
(99 WRX)
(04 WRX STi)
WRX STi
Tein Coilovers
Blouch TD05(24psi)
3" TBE
ID 1000cc Injecs
Walbro Fuel Pump
PSR Intake
PSR Headers
HD Clutch
(04 WRX STi)
WRX STi
Tein Coilovers
Blouch TD05(24psi)
3" TBE
ID 1000cc Injecs
Walbro Fuel Pump
PSR Intake
PSR Headers
HD Clutch
- Learner Driver
I'm a new gc8 owner and I have the exact same problem.....I charged the battery and still no go......where is the starter motor located do I need to jack the car up?
Sent from my ZTE T84 using Tapatalk
- Delivan
Check the earth wire that runs from battery to started motor... Check all earth strap contact areas.. Check battery terminals are tight.. MY guess would be a loos earth...
The starter is located up top, so engine bay access is fine, it's passenger side on the back of the transmission to motor housing. Follow the main positive and ground from the battery and they go straight to it. Take off the intercooler for best access, but you can leave it on.
Users browsing this forum: No registered users and 13 guests
