Boost issue
Thomasc9
Boost issue
Postby Thomasc9 » Sat Feb 25, 2017 5:22 pm
Hey all,
First post -
I have a wrx sti 2003 stock and recently installed a catback 3 inch
ever since, the car feels like it is not boosting the same as when it had the stock exhuast installed
im looking for some advice on how to resolve the issue and potentially somewhere local that I can take it to be looked at
Living in melbourne Hampton area (close to the city)
thanks
sssxc
Re: Boost issue
Postby sssxc » Sat Feb 25, 2017 5:27 pm
Get a tune...
Prob has over boosted and knocked which had pulled timing, added fuel and also pulled boost.
Sent from my SM-N910G using Tapatalk
Thomasc9
Re: Boost issue
Postby Thomasc9 » Sat Feb 25, 2017 5:45 pm
was told it wasnt necessary but thank you for your response will be getting a tune asap
have noticed fuel ecomy has been worse
Re: Boost issue
Postby mv75 » Sat Feb 25, 2017 8:04 pm
Totally needs a tune, it's post 2000. It is over boosting guaranteed.
Thomasc9
Re: Boost issue
Postby Thomasc9 » Wed Mar 01, 2017 4:26 pm
Took it to a shop, its running at 7psi max.. was told its most likely a leak or the waste gate actuator is bad
Re: Boost issue
Postby ryano » Wed Mar 01, 2017 4:52 pm
id say it running waste gate pressure, check for error codes
Thomasc9
Re: Boost issue
Postby Thomasc9 » Wed Mar 01, 2017 5:12 pm
getting it up on the dyno tomoz with the tuner
Re: Boost issue
Postby ryano » Wed Mar 01, 2017 6:23 pm
good post
Re: Boost issue
Postby mv75 » Wed Mar 01, 2017 6:37 pm
Better find any problems before you do that. A live view of it running will tell you straight away the problem (probably got the iam running below 8 so it's pulling boost due to it over boosting), as well as a few minutes of visual inspection as well as a grab of the waste gate actuator. Hopefully it's that simple, good luck tomorrow. :)
Thomasc9
Re: Boost issue
Postby Thomasc9 » Thu Mar 02, 2017 11:38 am
Well they were just going put it on the dyno to help diagnose.
sssxc
Re: RE: Re: Boost issue
Postby sssxc » Thu Mar 02, 2017 7:19 pm
Thomasc9 wrote:was told it wasnt necessary but thank you for your response will be getting a tune asap
Whoever told you that is giving you wrong information...
Andy05
Re: Boost issue
Postby Andy05 » Thu Mar 02, 2017 8:04 pm
How'd you go? Find the issue?
Thomasc9
Re: Boost issue
Postby Thomasc9 » Thu Mar 02, 2017 8:43 pm
Took it to springy motors today and he suspects a clogged cat.
what do you guys suggest?
Re: Boost issue
Postby mv75 » Thu Mar 02, 2017 8:50 pm
Thomasc9 wrote:Took it to springy motors today and he suspects a clogged cat.
Ah crap, I just totally realised, CAT BACK exhaust. Total waste of time. Yea, probably is clogged. Do it right and get turbo back then tune it. My bad as people usually get full exhaust and for some reason I filtered out the cat back bit.
Anyway, if it's possible to match your current cat back section, get a dump and new cat.
Thomasc9
Re: Boost issue
Postby Thomasc9 » Thu Mar 02, 2017 8:53 pm
the issue is matching it up.
bit of a mess atm
Re: Boost issue
Postby mv75 » Thu Mar 02, 2017 9:05 pm
Any good exhaust shop should be able to cut and weld new flanges. Although look at the option for a full 3" system, a 2nd hand original system, or just replace the cat. It may be a cost thing right now, but I would leave off the tune if you don't get a full 3" system.
Thomasc9
Re: Boost issue
Postby Thomasc9 » Thu Mar 02, 2017 9:30 pm
im thinking of just going to an exhaust shop and getting them to custom make one from the cat to turbo back but chances are it wont fix the issue anyway.
taking it to a shop asap - still haven't had it assessed on a dyno
Re: Boost issue
Postby mv75 » Fri Mar 03, 2017 1:57 am
Definitely find out If it is the cat first too. Do the temperature and rear o2 tests, unless they already did to come to the clogged cat conclusion instead of purely opinion.
Thomasc9
Re: Boost issue
Postby Thomasc9 » Fri Mar 03, 2017 1:04 pm
ok so it isnt the cat. any other suggestions?
Bad waste gate - not closing?
Bad turbo?
Re: Boost issue
Postby mv75 » Fri Mar 03, 2017 1:35 pm
Waste gate you can check yourself.
Grab the actuator arm and see if it's loose, try and move it, it should be very hard by hand. Be careful of heat of course.
Put the original exhaust back on. Flow will be worse with the original dump and cat still there while suddenly opening up to 3". Plus diagnosing is much easier if it's back to "it used to work back when" condition.
Check all hoses and the turbo intake that they are on, secure and not ripped.
Bad turbo, possible but unlikely unless there is a nice grinding noise coming from it.
Take it to someone who knows Subarus.
Users browsing this forum: No registered users and 20 guests
