Boost issue
Thomasc9
Re: Boost issue
Postby Thomasc9 » Fri Mar 03, 2017 1:44 pm
Actuator was checked as well as taking the hose off to the actuator. Still only 7psi. Anyone reccomend a shop in Melbourne that would be able to sort this out without 10 hours of labour ?
Thomasc9
Re: Boost issue
Postby Thomasc9 » Sat Mar 04, 2017 1:56 pm
Ive spoken to a few people who a fairly confident its either a boost leak issue or the waste gate may be partially stuck/open.
Is there anyone here locally that has made a DIY boost leak tester that i could pay to check for a leak.
Or potentially a shop that could undergo this test opposed to inspecting each individual compenent 1 by 1
Re: Boost issue
Postby mv75 » Sat Mar 04, 2017 2:44 pm
You have not replaced any of the hose links around the turbo / waste gate area have you? I am getting at that the restrictor pill is still there in the hose from positive pressure to the T piece?
Might want to give the boost controller a clean.
What is your boost gauge? Idle is around -20psi?
Thomasc9
Re: Boost issue
Postby Thomasc9 » Sat Mar 04, 2017 3:50 pm
idle is exactly on -20psi
did change the hoses on the tpiece but put the restrictor pill back in on the opposite side to the wastegate actuator
Not the boost controller because we have tried no controller, the stock controller and a manual controller.
Andy05
Re: Boost issue
Postby Andy05 » Tue Oct 10, 2017 7:04 pm
Did you ever figure this out?
Thomasc9
Re: Boost issue
Postby Thomasc9 » Sat Dec 30, 2017 3:59 pm
Hey Andy, I think that the diameter of the hose that i was using with the restrictor pill inside was too large.
lscislowski
Re: Boost issue
Postby lscislowski » Sun Dec 31, 2017 11:05 am
Some of this may make you understand why its at 7psi
viewtopic.php?f=6&t=86725
Users browsing this forum: No registered users and 20 guests
