06 wrx car problems
Anniewrx
06 wrx car problems
Postby Anniewrx » Sat Jul 15, 2017 11:53 am
Ok where to start. I love my wrx but its doing my head in 2wks ago it started turning over but not starting so did the crank n cam sensor.
It was still doing it so i sent it to mechanic he did the fuel pump it started 5 times then started the turn over but not starting again. I only use good fuel.
Put it on the diagnostic machine n no codes are coming up. My next move is FPR. ANY IDEAS PLEASE.
:surrender :wall:
Anniewrx
Re: 06 wrx car problems
Postby Anniewrx » Sat Jul 15, 2017 11:54 am
Its had full service history and i did the radiator about 2months ago n the o ring in the powersteering.
:surrender :wall:
Anniewrx
:surrender :wall:
Postby stockhorse » Sat Jul 15, 2017 12:04 pm
Go back to basics, fuel, spark, timing. Timing can't really suddenly change so that leaves fuel and spark. check spark at plugs. spark =yes move to fuel. spark = no look to leads, coils etc.
fuel =yes look to spark fuel=no look to fuel filter fuel pump relay etc.
Anniewrx
Postby Anniewrx » Sat Jul 15, 2017 12:15 pm
Thank you so much for replying.
Im thinking it has to be spark but i do teach myself all my car stuff :D . Fuel is good had mechanic test all that. Im buying spark plugs and leads today anyway. I just dont want to wreck her.
Would it be silly to do that battery as well. After trying to start it, it seems flat. I have a sub n amp that i think is affecting the car as well.
:surrender :wall:
Anniewrx
Postby Anniewrx » Sat Jul 15, 2017 12:22 pm
I checked spark n its sparking but not as much as i think it should. Sparks randomly if that makes sense .
:surrender :wall:
Postby 05-RSX » Sun Jul 16, 2017 11:10 am
Brant (Alarm).
Postby Delivan » Sun Jul 16, 2017 4:17 pm
Brant x 2 ... We have removed all our brants from our cars and replaced them with Mongoose systems
higginz92
Postby higginz92 » Sun Jul 16, 2017 7:44 pm
so its cranking but not firing? and you've replaced the crank and cam sensors? then your mechanic replaced the fuel pump and it started then stopped? have you got an OBD scanner? maybe crank and see what sensors aren't activating as in air flow sensor?
basics man, give us more information. Does it have spark when you crank it? Does it have fuel pressure pumping into the engine? put in the D check and feel the fuel hoses in the engine bay. Need more info brother!
Anniewrx
Postby Anniewrx » Mon Jul 17, 2017 7:16 pm
Okay ill start from the start. I started it it ran sheet n stalled n when i started it again it had a wierd popping sound. Went to start it the next morning n it would turn over but not start.
I did the crank n cam sensor. It was still doing it so i dropped it at the mechanic. He did the fuel pump. N it was still doing it so i took it back n watched him check for fuel n its getting fuel.
He said to do spark plugs so i bought them yest and yet to do them.
I also put a new battery in yesterday and its starting first time everytime but still going to do spark plugs.
Now it has this pungent smell when i drive it short distances. It was put on a diagnostic machine n no codes came up.
Ps im a women who loves cars and working on them. I just find this car hard to figure out haha
:surrender :wall:
Anniewrx
Postby Anniewrx » Mon Jul 17, 2017 7:17 pm
It wasnt getting fuel before the pump was done.
:surrender :wall:
Anniewrx
Postby Anniewrx » Mon Jul 17, 2017 7:19 pm
Thinking of just dropping it at the subaru specialist in the morning. Feeling defeated
:surrender :wall:
Anniewrx
Postby Anniewrx » Mon Jul 17, 2017 7:21 pm
Ive heard alot of bad things about the brant. I was wondering if it was disabling the car. But think more is going on
:surrender :wall:
jonoe
Postby jonoe » Wed Jul 19, 2017 8:52 pm
As others have said, I would be getting the alarm looked at, where are you located ? There are plenty of good Subaru specialists throughout Melbourne, most will be able to remove the Brant if it is faulty
Sent from my SM-G950F using Tapatalk
