extra plugs in ecu harness at ecu - what are they for?
James05351
Postby James05351 » Mon Oct 02, 2017 6:15 pm
found these behind the ecu kick panel they look professionally wired in but plug to nothing?
anybody know what they're for?ImageImageImageImage
Sent from my SM-G950F using Tapatalk
Re: extra plugs in ecu harness at ecu - what are they for?
Postby mv75 » Sat Oct 14, 2017 3:56 am
Dunno. Would be cool to get a whole main harness and trace them. But it's just also like the plugs that are behind my headlights that are taped up too, and there are more under / behind the dash as well. I find it easier to ignore them instead of trying to figure them out as everything works.
lscislowski
Postby lscislowski » Mon Jan 29, 2018 7:52 pm
Don't get too excited, nothing that will make your car go faster.
I've come across it before, If its the one I'm thinking of, its actually a earth joiner for some of your sensors. There is a plug that appears to have a cap on it, the cap is a joiner, that joins the wires together. I've had a look at a wiring diagram as I've come across it when I did my engine conversion. In mine it joined the earth of the engine temp sensor, front 02 sensor, rear 02 sensor and Air flow sensor. The wiring diagram calls it "shield and sensor ground joint connector"
Users browsing this forum: No registered users and 25 guests
