2002 sti front parking lights not working
Justinc1981
Postby Justinc1981 » Tue Nov 14, 2017 8:51 pm
Hey all,
We just purchased a 2002 sti for a project car and through me checking it out now it’s in the shed that the front parking lights don’t work when u turn the switch on above the steering wheel but the rear ones do - i have changed the bulbs but no difference.
I have also noticed that the HID ballist has been removed and normal bulbs are installed - all low and high beam and indicators are working normally
Any idea what I can check ??
Justin
jonoe
Re: RE: 2002 sti front parking lights not working
Postby jonoe » Tue Nov 14, 2017 9:38 pm
Justinc1981 wrote:Hey all,
Justin
Have you checked your fuses? I assume you checked the wiring / connectors when you changed the bulbs
Sent from my SM-G950F using Tapatalk
AJ
Red GF8 WRX Driver
Red GF8 WRX Driver
Re: 2002 sti front parking lights not working
Postby AJ » Wed Nov 15, 2017 12:48 am
The 02 STi didn't come with HID globes in Australia, so your globes are OEM.
Justinc1981
Postby Justinc1981 » Wed Nov 15, 2017 12:38 pm
Justin
yeh i have had a look at the fuse #5 that i found in the wiring diagram in the service manual and i have tested and confirmed it was all working
Justinc1981
Postby Justinc1981 » Wed Nov 15, 2017 12:41 pm
AJ wrote:The 02 STi didn't come with HID globes in Australia, so your globes are OEM.
hi there,
yes it looks like someone as JDM swapped the front headlights as they have the HID leveling plug in the back of the light.
all the lights on the headlight work except the front parking lights and the rear ones work
thanks
Justin
lscislowski
Postby lscislowski » Tue Jan 02, 2018 11:45 am
Can you read wiring diagrams? or know someone that does? Just had a look, both front and rear light use the some fuse, so it wont be the fuse. but it uses different plugs coming out of the fuse box inside the car. There doesn't to be any plugs between the fuse box and the front lights. Can send you a wiring diagram if you want. Only other thing I can think of, the new globes you put in, were they LEDs? LEDs will only work in one direction.
Justinc1981
Postby Justinc1981 » Tue Jan 02, 2018 11:51 am
lscislowski wrote:Can you read wiring diagrams? or know someone that does? Just had a look, both front and rear light use the some fuse, so it wont be the fuse. but it uses different plugs coming out of the fuse box inside the car. There doesn't to be any plugs between the fuse box and the front lights. Can send you a wiring diagram if you want. Only other thing I can think of, the new globes you put in, were they LEDs? LEDs will only work in one direction.
hi there,
after fault finding i was able to find the issue was loose wiring to the back of the globe holder - i have since fixed this and all is working now
thanks
Justin
