RCE Tarmac II coilovers with front Whiteline MaxC tops
rthy
Postby rthy » Fri Aug 11, 2017 12:14 am
Racecomp engineering (KW) Tarmac II coilovers
* Two adjustable damping (separate compression and rebound adjustments)
* Ride height adjustable
* Stainless steel INOX coated.
* 9/7kg/mm springs with helpers
* suit 5x100
Strut part no.
450 1003L
450 1102L
450 1102R
450 1003R
Front springs part no.
90-170* 18G14 (500lbs/ 60mm ID/ 6.7in free length)
helper 28G14
Rear springs part no.
70-170* 14G11 (400lbs/ 60mm ID)
helper 33J10
with Whiteline MaxC tops on the front
KCA250SM
Rear strut tops look similar to GD STI Group N Rear Strut Top Mount, fits the SG9 Forester
Was on my Forester when I bought it, spring rate too firm for the family...
Previous owner got them from Tuspeed and was fitted early 2016 and I removed them around Jan 2017
Note: The Foz had 5x100 hubs and STi running gear with Brembo brakes
Coilovers has no signs of leaks and no damage (some cosmetic)
Strut top balljoints are loose (but not floppy/play)
Not too desperate to sell, but I won't be using them anytime soon
$2,400ono
Details:
http://www.tuspeed.com/racecomp-tarmac- ... 10243.html
http://www.tuspeed.com/whiteline-maxc-m ... f73b95f922
Return to “Parts for Sale”
Users browsing this forum: No registered users and 8 guests
