Garage for sale, help me clean out garage.
rexmang
Postby rexmang » Tue Nov 21, 2017 6:58 pm
HI,
Anyone keen on pics, let me know via PM and I can MMS them as requested. Location is Mill park, Melbourne.
1: 225/45/17 imported Bridgestone potenza RE070 tyres. Made in japan, Roughly 2000km on them, near new. Removed due to change in rim size. $500
2:King spring lows suit 93-00 gc8 part number KSRL23 $100
4: Aps dump pipe mouth, hard to find. Splitter has been removed to allow for gas expansion, leaving a nice fat open mouth. $50
5: 02 sti alternator in excellent condition. Can be used on most subarus. $50
6: 02 sti clutch /slave reservoir. Good upgrade on gc8 as it moves it away from intercooler allowing larger intercoolers without hitting the stock gc reservoir $60
8: 6mt clutch and flywheel. Comes with bolts and pressure plate. Would be wise to machine before installation $150
10: Dual washer bottle. Good upgrade for Gc8's and other single washer subarus if you want to run waterspray $30
11: GDB ignition coils x4. $100.
12: GD starter motor removed off a 6mt. $50
13: 02 GD powersteering pump and reservoir $100
14: GD 02 sti radiator and fans. No leaks $80
15: Walbro 255 fuel pump suit 93-00 gc8. Was used literally 1 hour to troubleshoot a problem. Put back in sealed bag after testing , as new. $60
16: Garret wastegate actuator suit all stock position blouch/garret turbos. 1.5bar spring (21psi) $70
17: GC8 rear r160 drive shafts, equal length suit MY99+ models. $70 pair.
99 V5 STI Team coupe| built 2.5L|Dom 3 XTR 8cm@26psi|Water to air goodness| 07 STI 6MT dccd Short box | Brembos|
suba.sonic
Re: Garage for sale, help me clean out garage.
Postby suba.sonic » Wed Nov 22, 2017 10:14 pm
I'm interested in your p18 exhaust housing you have a PM
Carbon-Goodness
Postby Carbon-Goodness » Sat Feb 03, 2018 5:22 pm
Hey mate, are the tyres still for sale?
If somebody says to you, "can i ask you a question?" and you reply, "no", then you've just contradicted yourself - think about it.
rexmang
Postby rexmang » Fri Feb 09, 2018 9:43 am
yes
AJTbone
Postby AJTbone » Fri Feb 09, 2018 2:39 pm
Hi mated, pm'd regarding the ps pump.
Return to “Parts for Sale”
